Question about Refrigerators
Accessing and cleaning coils on Kenmore Elite Side by Side
I am having trouble getting access to all of the coils in order to clean them; I can reach only the front coils; how do you access the coils toward the back.
Bob
  • Refrigerators Master
  • 43,501 Answers
To reach the back coils you need to pull the fridge out and take off the cardboard type cover...
I often use an air compressor with high pressure air to blow out the coils..makes a mess but oh, well, sometimes you got to do what you got to do...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Heatman101
Posted on Feb 07, 2010
I just cleaned the coils on my fridge with very little mess, here's how. Take off the back panel and use it as a template to cut a piece of cardboard the same size and shape. In the cardboard, cut a hole the size of your shop vac's hose. Place the cardboard on the back of the fridge and block or screw it so it stays in place. From the front of the fridge, remove the grill, and use compressed air to clean the coils. The shop vac will pick nearly all of the dust. This can work on any refirgerator that has access front and back.
Posted on Dec 08, 2011
  • lynn maas Jul 21, 2012
    My refrig grate is greasy (Not cleaned by former owner). Will compressed air work?
How do I clean the coils underneath my Frigidaire 26 cu ft side-by-side refrigerator?
Hello friend, thank you for your post!
I see that you want to clean the coils underneath your Frigidaire refrigerator. The best way to clean the coils is to remove the toe grille and use a vacuum extension brush to reach the coils. I hope this is helpful. -Matt
Sep 12, 2014 | Frigidaire Refrigerators
I have a kenmore elite side by side frige and it does not get cold
Check out these tips that I wrote about that...it is a great place to start trouble shooting your unit...and something thatyou can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 20, 2011 | Kenmore Side by Side Refrigerator
Access to the door relay of Kenmore Elite?
If you are attempting to replace or troubleshoot the door latch mechanism, the following link explains how to access and/or replace:
http://www.fixya.com/support/r3575840-replacing_a_door_latch
The easiest method is to go through the door bellow. You can attempt to reach the latch by removing the top panel of the washer and working from the top, but it can be difficult to reach for some people. If you have quesitons, please post back and let me know. I hope this helps you.
Apr 28, 2010 | Kenmore Elite 45986 Front Load Washer
Coil replacement
I'm not an expert but assuming you ordered the coils for your dryer your dryer must have them. I just finshed repairing my kenmore gas dryer after about 10 minutes the gas would shut off. This is becasue the coils that are on top of the gas line before the ignigter were defective. The coils control the gas valve and when my dryer got hot the coil being defective would close the valve. There are 2 coils a 2 prong and a 3 prong. Remove the front panel to gain access to the bottom of the dryer from there you will see your coils about as round as a quarter and 10 or so high. unscrew the screws holding down the retainer and undue the electrical clip. reverse for the install. good luck!
Dec 13, 2009 | Kenmore 72802 Gas Dryer
What does F2 code mean with the Kenmore Elite HE3?
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Access to clean coils on kscs25inss00
You need to get a bottle brush they are about 18" long maybe longer and made for getting into these area's to clean the coils. My frig is set up the same way and hate it. Cause when they are that dirty cause's so many things to happen all bad. I have used my air compressor to blow them clean and then chase little dust bunnies around the kitchen. I have been thinking about this same problem for awhile now and bottle brush is the best option for now that I have heard of. ken
Jan 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
Not draining or spinning
probably not drain hose ..remove screws bottom cover remove clean out port on pump and clean.. after removing as much water as possible from tub
Nov 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Bottom Freezer Refrigerator Model 795.7554
the condenser coil on this is located in the back side and removal of the rear cover is need to get to the coil. It's on the right side looking at the back. make sure to unplug the ref before taking the back off.
Aug 09, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refridgerator
The best way it to buy a coil brush and use your vacuum as you clean. A coil brush is long and skinny and can be bent to reach in tough spots. Some people will blow it out with an air compressor but it is very messy.
Oct 07, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
1,628 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
