Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse in fuse box? What is problem?
  • Hotpoint Master
  • 12,061 Answers
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Posted on Feb 07, 2010
I have a Hotpoint DWF70 dishwasher everytime it goes on to the drying cycle it blows the main fuse in the circuit box. There appears to be water still in the unit when it goes on to the drying cycle, any thought?
Posted on May 16, 2010
I have a hotpoint dishwasher BF1620,its leaving a film on everything at the end.
From what you're describing, there might be an issue with the detergent reacting with something in the water. Also, check the water temperature. Any detergent needs to have HOT water--at least 120 degrees or above to activate and clean properly! I also recommend ALWAYS using the high temp wash, boost, or whatever it's called to keep the water very hot throughout the cycle if your washer has that feature.
Sep 11, 2015 | Hotpoint Dishwashers
No power. Will not turn on
It may have tripped the internal breaker, and or the house circuit breaker. Go tot the house fuse box and check that first.
Mar 05, 2014 | Whirlpool Gold GU2275XTVy Dishwasher
Do these 'portable' dishwashers 'heat' water prior to washing? i have customer complaining bout the dishes not coming clean..yet the water entering the dishwasher is cold, does not appear to heat water...
Most dishwashers require a minimum 120 degree inlet water temp. The heating element will boost this up during the main wash cycle to aprox 140. Do not hook a dishwasher up to inlet water temps above 150.
Feb 06, 2010 | GE Hotpoint HDA3500N Dishwasher
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
May 07, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
My whirpool dishwasher model du930pwps2 stopped working
sounds like the fuse on the control blew. you can replace the fuse for around $20 or you can cut and splice the wires for free. If that doesnt work then you may have a loose conection in your junction box under the dishwasher.
Dec 01, 2008 | Whirlpool 24 in. DU930PWP Built-in...
My dishwasher
Nov 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
The fuse in the plug keeps blowing. Initially it would run for a while - sometimes 3 or 4 cycles - before blowing. It now blows the fuse the second that I plug in to the socket, even with the on/off button...
Lower the outlet hose into a washing up bowl, it should then Drain. Check the heater to see if it is earthing you get to it by removing the right hand side panel.
Nov 28, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
1,336 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
