My bosch front loading washing machine makes terrible noise when spinning and machines jumps about
    Genius:
  • Washing Mach... Master
  • 1,460 Answers
This could be due to faulty drum bearings or loose suspension unit. Further information needed....
Posted on Feb 08, 2010
Bosch classixx wvf 2402 at the end of the dry spinning cycle, 5-6 minutes the machine makes a terrible noise. What could this be?
Can you describe the noise? Is everything else working normally? From what you are saying, my guess at this point would be that the pulley on the motor is working loose.
Jun 13, 2014 | Bosch Classixx WVF 2402 Front Load...
Bosch washer noisy
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jan 22, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Its making a terrible noise when spinning and wont drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2011 | Washing Machines
The machine won't pump water or spin and makes nasty noise. When I turn the drum by hand there is no noise and feels normal.
heatman101
Jul 08, 2011 | Bosch Washing Machines
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Why no spin?
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 21, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washing machine makes a noise (like rocks tumbling) when machine is draining water
heatman101
May 15, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Washing Machines Logo
104 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
