Question about Refrigerators
Top food cold, bottom food frozen
Food in bottom of refrigerator is frozen, stuff on top shelves is just cold.
  • 572 Answers
Adjust the shelf temps
Posted on Feb 07, 2010
I have a frost free refrigerator (MODEL #: FGTD 20V4GW2 and SERIAL #: ba00230071) yet the ice/frost builds up of the door, top and front of the freezer. Also the bottom compartment where the milks,...
if ice is on the door and ceiling and frozen water dropleats on the food packages the door was left open and the air ducts are frozen.when you open the freezer door do you hear the fan blowing,if not it could be bad or iced up,if the ice is on the inside back wall of the freezer you have a defrost problem,get back to me and tell me if the ice or like snow is just on the back wall or if the door was left open ice will be on ceiling ,door and shelves and food packages,also that's not a good model number if the freezer is on top look at the left wall up near the ceiling in the fridge section,you should see a tag there with the model number.
Sep 25, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
I have a GE Profile model # TPX2451YEBS side by side fridge. Both sides are not cold on upper part. The food in fridge on top 2 shelves and door shelves is just cool. The frozen food in door...
Sorry to hear about your problem.
Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Jan 02, 2011 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
Cold on the top part but not cold on the bottom
Check the fins in the back of the "bottom" part for frost / ice buildup. It may be time to defrost your fridge.
Alternatively, if there is a lot of food crammed onto the top 2 shelves, it can prevent the air from circulating around the fins. Also check your door gaskets, especially if you have of frost / ice building up on the fins.
Jul 12, 2010 | Dometic RM2652 Refrigerator
Top is frozen lower shelves food is dethawing
One of two things is going on here, either the door is not closing properly (or some one left it open), check the seal all the way around especially at the bottom.
Or most likely you have a refrigerant (freon) leak that has left the charge low enough that you are unable to get it to cool throughout. A leak on this type of unit is usually in the evaporator in the corner where a weld was made. The evaporator is about $189.00, with refrigerant a new drier and supplies I bet it would run about $450.00 to repair.
Apr 26, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The temperator is uneven
Our side by side GE model # GSS25SGPESS is not cold on the food side. the temp in the refrigerator is 48 degrees.
Apr 18, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Food freezing in refrigerator and water dripping
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Nov 24, 2008 | Whirlpool Refrigerators
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
