Question about Car Audio & Video
Removing a car radio.
Hi My problem is removing a Pansonic car radio from a 1995 Mitsubishi Diamete. Are there any special tools needed?
    Sergeant:
  • 306 Answers
There is radio keys that slide into the sides of the radio and unhook the clips that hold it into the cage.
Posted on Feb 08, 2010
I need to remove my 6 cd changer am fm radio how does ut come out please help so i can replace it
you need the radio removal u shaped tools. you can buy for $5 at uto store.
SECTION 415-01: Audio Unit 2002 Escape Workshop Manual
REMOVAL AND INSTALLATION Audio Unit
Special Tool(s) s2k~us~en~file=st1445a.gif~gen~ref.gif Radio Removing Tool
415-001 (T87P-19061-A)
Removal and Installation
  1. Disconnect the battery cables. For additional information, refer to Section 414-01 .
  1. Remove the audio unit.
    1. Insert the special tool into the radio face plate and release the radio retaining clips.
    1. Pull outward on the special tool and remove the audio unit from the instrument panel.
  1. Disconnect the connectors.
  1. To install, reverse the removal procedure.
Apr 22, 2011 | 2002 Ford Escape
I need fix code radio for my 1995 bmw
You probably need the special 5-sided tool to loosen the two screws under the little doors on either side of the faceplate to pull out the radio. Try other tools, but if the screws are really tight, you need the proper tool, which you can buy on line.
Slide out the radio, read the serial number, and give it to the service writer at a BMW dealer. If they want to charge you money to look up the code, try another dealer.
Mar 20, 2011 | 1995 BMW 3 Series
How do i change a head gasket on a mitsubishi mirage
This if a big and very important job. It requires more than you can get here at FixYa.com. You need many special tools not to mention a place to work. Do you have a garage you can work in for at least two weeks? You will probably have to get the heads worked on. Then there is the reassembly.
If you are serious about this, you need a motors manual for this make and model plus all the special tools and a strong helper.
Mar 06, 2010 | 1995 Mitsubishi Mirage
Need radio code for 1995 saab 900 se
sorry but there is nowhere/body to find out what the code is...the first owner could have written it in the service book but "is that too much to ask...."you will either have to replace radio or an i.c.e.dealer may bypass the code for you .
Mar 01, 2010 | 1995 Saab 900
How do remove the radio panel from a 1995 Mitsubishi Lancer
normally four slots in radio specil keys go in to pop radio out chek local dealer fo keys there real cheap
Feb 25, 2010 | Mitsubishi Lancer Cars & Trucks
Need to remove radio from a 2000 Mitsubishi Galant.
if its mounted in the raido resess you need a special tool that slides down the edges to free the retaining springs y could try a thin knife
Nov 14, 2009 | 2000 Mitsubishi Galant
NEED RADIO CODE FOR 1995 325 BMW. ITS A BMW FACTORY INSTALLED, ORIGIONAL RADIO. BATTEERY DIED AND IM LOCKED OUT
You must remove the radio (unscrew the two security screws under the small flaps at the left and right sides of the radio face), get the radio serial number from th etag on the radio, then go to a BMW dealer, who can look up the security code.
The two screws require a special tool for removal. you can get it at Bavarian Autosport:
http://www.bavauto.com/shop.asp?HC1=0&Htarget=search.asp&HCY=1995&HCM=325i&SearchStr=radio%20tool
Nov 06, 2009 | BMW 325 Cars & Trucks
Process in how to do it. Where start? Special
try another dealer they are able to use the vin as long as the radio has not been changed
Oct 20, 2009 | 2001 Mitsubishi Eclipse
I need to remove the radio in my 1998 mountaineer
you need specail radio removal tools. they spread 4 spring clips.
  1. Remove the radio chassis.
  2. Insert Radio Removing Tool into the radio face plate and release the radio retaining clips.
  3. Pull outward on Radio Removing Tool to remove the radio chassis from the instrument panel.
Special Tool(s)
Radio Removing Tool
May 12, 2009 | 1998 Mercury Mountaineer
Mitsubishi Diamante 1995 (2.5L) harmonic balancer...
you def will not be able to drive the vehicle with no balancer due to the fact that is the main source that runs all your belts...all you should need is a harmonic balancer pulley remover..
Dec 09, 2008 | 1995 Mitsubishi Diamante
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
