Question about Texas Instruments TI-83 Plus Calculator
Ram cleared? - Texas Instruments TI-83 Plus Calculator
  • kakima May 11, 2010
    Are you asking how to clear RAM? If so, press 2ND [MEM] and take it from there.
    Problem Solver:
  • 12 Answers
That means memory cleared
Posted on Mar 25, 2010
Can I retore a cleared progam on my ti84
If you only cleared RAM, a program that was loaded no longer resides in RAM, but if it was archived, it should still be available.
If you cleared all Including Archives, then it is lost.
Sep 03, 2014 | Texas Instruments TI-84 Plus Calculator
Ram cleared, how to reset ram memory
If the calculator says RAM Cleared, then the RAM is cleared and there is no need for you to reset it. again.
If the calcularor says RAM Cleared everytime you turn calculator on, it may be due to a depleted backup battery.
Sep 07, 2011 | Texas Instruments TI-84 Plus Silver...
Says printing but nothing is coming out
If it says it is printing and no paper is being fed, and you are not getting any paper jam indicators, thats not good.
To get this reset you may have to do a RAM CLEAR. This will mean all documents in memory and all programming in the machine( date, time, quick dial numbers etc, etc) will all be lost, and will have to be re-entered.
If you want to try the RAM CLEAR do the following....
Press Program, *, 3.....display should say All RAM Clear ( enter/cancel).....to perform the Ram Clear press ENTER
To finish without doing the Ram clear press CANCEL.
Apr 27, 2010 | Muratec F320 Plain Paper LED Fax
TI-83 Plus ram cleared message when turned on
It calculator tells you Ram Cleared each time you turn it on, the most likely reason is that the backup battery is depleted. Its role is to keep the memory modules electrically refreshed when calculator is turned off. If the backup battery is dead, the memory is erased when you turn calculator OFF. Main batteries no longer supply power and the contents of the memory are cleared.
  1. Check that main batteries are good and inserted in calculator.
  2. Turn calculator OFF.
  3. Replace the backup battery.
  4. Turn calculator ON.
  5. Press the [CLEAR] key to erase the "Ram Cleared" message.
Jan 19, 2010 | Texas Instruments TI-83 Plus Calculator
Gives error memory message when tries to change
See if the cursor is checkered. If so, the calculator is out of memory.
You may have very little memory available and then wanted to create a table with a very small DeltaTbl (the table step). If the step is small, and the domain is large, very many points will have to be generated and that may make the calculator unable to comply for lack of RAM.
I suggest you free some Ram by clearing the lists, clearing the entries. To do so you press [2nd][MEM][3:Clear Entries] to clear entries, then press [2nd][MEM][4:ClrAllLists] to clear the lists.
Alternatively, you can just reset the Ram by pressing [2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]. Then clear the Ram Cleared message and start again your table.
Hope it helps.
Thank you for using FixYa and for rating this solution.
Dec 01, 2009 | Texas Instruments TI-84 Plus Calculator
RAM CLEARED?
The most likely reason is that the backup battery is drained. Change the backup battery. When you get the Ram Cleared message, just press [CLEAR] to erase the message and start using the calculator.
Hope it helps.
Oct 28, 2009 | Texas Instruments TI-84 Plus Calculator
The Screen displays random lines and numbers.
Clear the screen. Reset RAM :[2nd][MEM][7:Reset][All ram] [2:Yes] Ram cleared is displayed. [Clear] the screen.
Hope it helps.
Sep 19, 2009 | Texas Instruments Office Equipment &...
My calucator got wet today wat do i do?
Let it dry for a few more hours or overnight. The RAM has most definitely been cleared, however, and there is little chance to recover any custom formulas you've put in there.
Mar 05, 2009 | Texas Instruments TI-84 Plus Silver...
How do you restore a TI-89 Titanium clac
Perhaps one of the following sources will be helpful:
To reset the TI-89 family, TI-92 family and Voyage 200 graphing calculators, press [2nd] [6] (reads MEM over the key). The [F1] menu appears and contains the following options:
  • All RAM - Clears all variables and programs from RAM only. This will not delete items from Archive or Apps.
  • Defaults - Does not clear any files from the calculator. Instead, this option resets the calculator settings to default, including the Mode, Graph Format, Table Setup, and other settings.
  • Vars - Clears all variables from Archive (Flash ROM). This option will NOT delete Apps or variables stored in RAM memory.
  • Apps - Clears all Apps from Archive. This will not delete any variables.
  • Both - Will clear all Apps and Variables from Archive. This will not delete any Variables from RAM.
  • All Memory - Clears everything from RAM and Archive, leaving only the Calculator OS and its components.
For example, I think you will want to follow the last step above... which would be to press [2nd] [6] [F1] [1] [1] [ENTER] [ENTER].
Also, if you are looking to clear all the RAM in another way I would take a look at the guidebook, which is downloadable from the following site in PDF format.
http://education.ti.com/downloads/guidebooks/graphing/89ti/TI89TitaniumGuidebook_Part2_EN.pdf
Take a look at page 951 and 952 for another way to clear the RAM
Jan 29, 2009 | Texas Instruments TI-89 Calculator
Texas Instruments TI-83 Plus Calculator Logo
190 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
