Question about DeLonghi Heating & Cooling
Heater stopped working suddenly, power light on but not heating up
The same thing just happened to mine..took it apart but still nothing doing
Posted on Feb 07, 2010
Vornado eh1-0020 was working fine and just suddenly stopped. No lights, no hum - just totally dead. Opened it, dusted, connections look ok. Anything else I can check or is it just
These heaters have a thermostatically controlled safety switch. It works very similar to your household iron for pressing clothes. On your iron, when the unit heats up the metal in the switch expands and "clicks" open stopping the power from heating up the element any more, then when it cools down it "clicks" closed and power is applied to the heating element again. Now here is the problem... in your heater, the elements are over-heating and causing the safety switch to "click" open stopping ALL power from going to the unit. IF you sit there long enough, you will eventually hear the "click" of the switch cooling down and then you will be able to turn it back on for a short time - then it will do it all over again. =( Unfortunately, this seems to be a common problem with this series of heater. There really is no "good" repair option as the price you will pay for someone to "fix" it, would probably be better spent going towards a new heater.
Oct 27, 2011 | Vornado EH1-0020-01 Compact Heater
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Lakewood radiator heater model number 5101. The heater just stopped working all of a sudden. The buttons still light up when switched on but there is no heating. please help as I dont have any other...
Sounds as if the element is burnt out or the tstat is broken. the tstat is the more common as they use very cheap ones. Unfortunately you can't get these. My suggestion is to buy a new one.
Jan 27, 2011 | Lakewood Oil-Filled Electric Radiator...
I have a model 71-408 B which just stop heating
If I understand correctly, you have electric water heater.
Heater suddenly stopped heating.
Four things cause sudden loss of water heater.
1) Reset button located under the top cover is tripped > turn off power, remove cover, press reset button > if reset keeps tripping, go to the troubleshooting link shown below.
2) Electric power to heater is interrupted > check circuit breaker > test for voltage > look for loose wire on breaker
3) Upper element burned out > test and replace element
4) Upper thermostat bad > replace upper thermostat
Reset button is best suspect.
Here is a link for complete troubleshoot and homeowner repair of electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Nov 19, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
2002 taurus, power windows all stopped working at once along with lighted window switches. Drivers window stuck down. Relay was hot! Also heater blows cool air, started doing this after I added radiator...
LOOK FOR BLOWN WINDOW CIRCUIT BREAKER.YOU HAVE A SHORT IN WINDOW SWITCH OR BAD WINDOW ELECTRIC MOTOR.YOUR HEAT PROBLEM IS A STOPPED UP HEATER CORES.THE STOP LEAK STOP ITS HEAT.THE STOP LEAK HAS STOPPED OR PLUGGED YOUR HEATER CORE SO COOLANT CANT PASS THROUGH IT.YOU GOING HAVE TO FIX RADIATOR LEAK AND REPLACE HEATER CORE TO GET HEAT AGAIN.
Jan 28, 2010 | 2002 Ford Taurus
Fan and light no longer turn on
possibly the thermal overload sensor failed internally? as indicated in the instructions there is a overload sensor and thay will typically fail in others appliances.
Oct 30, 2008 | Reiker RRC120004 Brushed Steel Ceiling Fan
Quit working
Based on the limited info.I have, it sounds like the heating element is not getting power. suggest visually inspecting the switch and thermostat for burnt wires. Also check the heating element for broken electrode.
Nov 08, 2007 | Comfort Zone CZ-530 Compact Heater
Heating & Cooling Logo
182 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
