Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I have a Sears Craftsman Lawn Tractor, Model 917.272751, S/N 060503B025327, B/S engine 18 Hp Model 31H777, Type 0202-E1. I have a new battery and a new starter on it but when I hit the starter the engine will maybe turn but mostly I just here a " clicking noise. Possible solution/s please ?? Bob < samvet90@charter.net >
  • erex 01
    erex 01 Oct 08, 2017
    This is going to sound odd but give it a try. Make sure you have a decent bolt on the negative battery terminal, I put stainless on mine (easier to get on and off). Reason for this is that Craftsman lawn tractors are notorious for shorts in the electrical system. I've checked mine with no apparent shorts but just the same, the next day, my new battery would be dead. Yes the key was off & no apparent current draw. Every time I use my tractor I disconnect the battery until next time. I haven't had a problem since. Now for the clicking noise, I haven't troubleshoot this as of yet however I did notice my engine will just click unless I open the hood and spin the flywheel housing 1/2 turn. I then turn the key and it starts right up. I'm thinking I have bad spot on my flywheel but it seems odd that it "always" stops on the "bad-spot" each time the motor is turned off. Not sure but spinning the flywheel just a little bit works every time on my Craftsman Garden tractor.
If you are sure the battery has a good charge, then it's either going to be your starter, or the spark plug. The clicking noise makes me think it's not the starter. I would say dead battery but you have stated it's a fresh battery. So... next step would be to have a look at that spark plug. It may either be fouled, or otherwise in need of replacement.
My advice, is take the battery to AutoZone and have them verify the battery is indeed good. And if it checks out, get a new plug while you are there.
Posted on May 23, 2010
Samvet90. Did you ever figure out what was wrong. I hahve that same problem.
Chris
Posted on Mar 08, 2010
  • 677 Answers
Have you checked the oil in the crankcase, is it full ?
Has engine been sitting along time ?
Have you double checked all the battery conections, all are tight, good ground connection to motor ?
Please let me know.
Posted on Feb 07, 2010
Is their a manual available for the craftsman DLT 3000 18. 5,lawn tracter model no. 917.27 58 20, 42in.deck
i would look under sears/craftsman web sight or google this for manual.im sure there will be one.
Oct 28, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where can I find the manual for a garden tractor Craftsman model 944.604192 18 hp LT2000?
You can find that on the Sears site that has all the manual downloads. They are here. Sears has 2,054 lawn tractor manuals on here. Yours should be there.
http://www.managemylife.com/mmh/owner_manuals/search?query=Lawn, tractor
Jun 11, 2011 | Craftsman Garden
I have a sears craftsman tractor,18 hp electric start. No. 917.254860. engine no. 422707,type no. 1522.01. briggs and stratton. engine won,t turn over. Replaced plugs,coil,carborator rebuilt to specs. New...
From your description it seems that the starter is not engaging to turn over the engine. First ensure all the connections of the thicker cables to the battery, starter and tractor frame are clean and tight. If starter motor is turning but still not engaging it will mean that the pinion on the starter motor is binding on the shaft. You can buy a new starter pinion gear from your local B & S agent.
To replace pinion, remove starter motor from engine, remove old pinion and put on new one and reattach starter to engine. If fuel & spark are right you should be up amd running.
Sep 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
NEED TORQUE SETTINGS FOR 18 HP MODEL 31H777-0297-E1. ROD BOLTS AND HEAD BOLTS. IS THERE A PATTERN TO TIGHTENING HEAD BOLDS
hi
con rod bolt torques are 150 in/lb or 12.4 ft/ lb
cyl head bolt torque is 220 in/lb or 18.5 ft/lb
here is website for parts and manual
http://www.briggsandstratton.com/maint_repair/manual_and_more/docsearch.aspx?enginelookfor=31h777-0297-e1
i would torque them in this sequence
start from bolt centre top , then bolt centre bottom, then bolt left upper , then bolt btm right, then bolt bottom left , then bolt upper right , then bolt centre left
should be 7 bolts 5/16 x unc
check out website its good so is www.partstree.com
cheers paul
Aug 16, 2010 | Briggs & Stratton Garden
Craftsman Lawn Tractor, 18 HP, 44" Cut; No SWtart!
Check the by pass switches on the seat, clutch pedal, and check the fuses.
May 15, 2010 | Craftsman Garden
Will a snowblower attachment model number 842-240743 fit on my riding mower
i have a snow blower attachment mod# 842.240530 sears and a sears 18 hp tractor mod # 917.258492 with no instructions on how to install them together? i dont know where all the parts go.
Oct 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 31h777 engine it will not charge the battery
the stater on the engine might be giving you problems or the battery might be going bad
Jun 26, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need instuctions on how to put plow on.
There is a fairly new sears site (as of 4-11-08)that includes all manuals for all sears products:
http://www.managemyhome.com/mmh/prod...Display.action
Make sure that Scripts are enabled in your browser.
Enter lawn or garden tractor manuals as:
Type of Product:
lawn mower (or tractor)
Brand:
craftsman
Model no.:#
(example: 917.276081)
make sure if the model has a suffix (like 917.276081 or 917.276082) to use it. This also works for all attachments, and add-ons.
May 18, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Replace key assembly
any small engine repair shop should carry that switch - or sears . com - just put in your model number
Oct 21, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
759 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
