Question about EliteGroup D6VAA-Raid Motherboard
Can 1400MHZ CPU work in elitegroup D6Vaa motherboard
    President:
  • 2,351 Answers
Posted on Feb 07, 2010
Testimonial: "Thanks for the answer."
Sys cooling fannnot working
Google the Internet for a CPU fan for your model motherboard/CPU.
Feb 14, 2013 | EliteGroup NFORCE4M-A Motherboard
Will a dual core or multi core processor fit into and work in a elitegroup 761gx-m754 motherboard?
Unfortunately there are no dual core CPUs for this motherboard. The 761GX-M754 motherboard has a 754 socket which supports the Athlon 64 / Sempron CPU. AMD never released a dual core CPU for the socket.
I wish that I had better news for you.
Sep 17, 2011 | EliteGroup 761GX-M754 Motherboard
Just purchased CPU upgrade (Pentium 3, 1.4Ghs, 512K, 133Mhs) for my DFI TA-64B motherboard. The manual that came with the motherboard notes: "The frequency ratio (SW2 Switch) of CPUs greater than 8x has...
Your CPU needs a ration of x10.5 (10.5*133~1400Mhz), thus according to what you wrote, you won't be able to use it with your existing motherboard (or - only be able to use it as 1.00Ghz CPU).
Mar 14, 2010 | DFI Twin Sockets TA64-B Motherboard
If cpu fried is there any hope for motherboard
Yes there is. There is a slight possibility that the motherboard sitll works, but it is better to test it with a processor of the same type, or one that has the same socket to actually see if it works.
If you need further assistance please post.
Thank you
Mar 08, 2010 | EliteGroup GeForce 6100SM-M Motherboard
Can the cpu be upgraded to BX80526C1000256! If yes what modifications need to be made? Motherboard is EliteGroup P6STP-FL
Hello!
If you want upgrade you CPU, you must first know, specification of motherboard.
If the motherboard can´t see a new CPU, more exactly bios, you can try only one upgrade bios.
I give you a link for a manual and upgrade bios.
When you upgrade bios, try new CPU, if bios again don´t see a CPU, you can´t do anything about that.
Nov 03, 2009 | EliteGroup P6STP-FL Motherboard
No Power to Motherboard...
Here are some steps.
Attach the monitor in your CPU and plug it, see if the monitor powers up. If it did, then no problem in your power supply,
Detach the RAM or Memory of your CPU and put it back in, in the different slot. and power up your computer.
Check the cpu power switch if it is correctly attached to the motherboard.
Oct 26, 2008 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Reboots every 30 seconds or so
Check all your fans and heat sinks including power supply one
Also check CPU heat sink for fluff and dirt
Sep 09, 2008 | Foxconn WinFast K7S741MG Motherboard for...
EliteGroup GeForce 6100Sm-M Problem
4 things can cause this MB to do as you mention.
Bad CPU or the MB is not sensing the CPU fan and is protecting CPU from overheating.
Bad or inconpatible memory, If multiple sticks use only 1 at a time, This MB is known for having problems with both slots filled most of the time bios resaves can fix this but just set up with 1 first.
Reset the bios, Make sure the reset jumper is set back correctly.
Make sure it post without any extra harware hooked up first then add them.
The beeps are a old style of signaling the problem, You can find charts online that will tell you what the beeps mean long and short.
Nov 27, 2007 | EliteGroup GeForce 6100SM-M Motherboard
EliteGroup 741GX-M Motherboard
Your computer has memory problems. First check the video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad or they are mismatched .The CAS latency has to be the same and compatible with your M/B. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
Sep 25, 2006 | EliteGroup 741GX-M Motherboard
EliteGroup D6VAA-Raid Motherboard Logo
71 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
