Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error message on printer: paper output slot - can't find jam anywhere and have done what manual suggested. Was printing a 4x6 in landscape position* from my mac to the printer when it showed error message. No paper visible even when turning machine to side and opening. *had switched it around from portrait position because it printed wrong direction and only partially. Wish I had seen warning on p.37 first not to load this way - why have the grid markings on paper tray if 4x6 shouldn't be loaded as such? Help
  • lizzylou Feb 07, 2010
    well.... after 6 weeks of being jammed and trying different things and my husband and I both spending several hours, I have my printer back! The 4x6 paper was finally released/ejected and I didn't even have to clean the printer head. Did take out all the cartridges and put back in but for some reason, the paper finally ejected on its own. It wasn't even stuck or messy with ink. Computer glitch "talking" to printer? Printer confused? Anyway, ecstatic to have my faithful printer back and will ONLY use 8x10 print paper for now! Thanks!
    sent an additional. For some reason the paper (4x6) ejected on its own. It was clean, no smeary ink but did take out all cartridges and put back in. Hooray. Thanks.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First, verify that there is actually no paper jam (open all the doors, take out the paper tray, take out the cartridges and visually inspect). Turn printer off and unplug the printer from all cables (power, USB, etc). Try to hold it upside down and gently shake it so that if there is any paper inside it’s removed. If still it’s not resolved then clean the print head. To clean the print head take a hot water towel with the printer unplugged and the cartridges out, clean it till the time you see there is no ink residue on the towel.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
My Canon Pixma MP600R insists that paper is jamed in machine, despite the fact that jam has been cleared and paper is being ejected when machine is switched on
The simplest thing would be to try unplugging the printer from the power source. Let it rest for 5 - 10 minutes then plug back in to the power supply and see if that resolves the problem.
If not you are going to need to do a thorugh inspection to verify that all paper remnants have been removed.
The following is for the MP600:
Issue: ERROR LCD: The paper is jammed. Clear the paper and press [OK].
Solution: Removing paper jams MP600
Removing Obstructions or Jammed Paper If [Paper output slot - The paper is jammed. Clear the paper and press OK] appears on the LCD, follow this procedure to clear the paper jam Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
Clearing paper jams inside the printer
Clearing credit card-sized or 4" x 6" paper jammed inside the printer
ASF / Paper Output Slot
  1. Turn off the printer.
  2. Remove paper from the ASF.
  3. Gently pull the jammed paper out.
    1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
    2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
      The above illustration shows a PIXMA MP500.
  4. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note:
    Be careful not to touch the components inside the printer.
  5. Turn on the printer and confirm that the Alarm light is off.
    (If the jammed paper remains in the printer, the paper may be automatically ejected.)
  6. Load paper back into the ASF.
  7. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Paper jams inside the printer
  1. Turn off the printer and disconnect the power cord and USB cable.
  2. Remove the jammed paper slowly using the following procedure.
    1. Open the rear cover to check if the paper is jammed.
    2. Pull out the cassette and check if the paper is jammed inside the cassette area.
    3. Stand the printer with the left side down, holding the document cover.
    4. Press the tabs together and pull the green cover toward you.
    5. Check if the paper is jammed.
      (If you were not doing Duplex printing, you do not have to follow this procedure.)
    6. Close the green cover and place the printer back to a normal position.
  3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  4. Load paper back into the ASF or cassette.
  5. Press to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
  2. Load the same paper type that is jammed inside the printer in portrait orientation.
  3. Power on the printer.
    The paper stock in the ASF will automatically feed the jammed paper from the printer.
  4. To resume printing, load the paper in portrait orientation.
If 4" x 6" sized paper was loaded in landscape orientation in the cassette and did not eject (exit), please follow this procedure.
  2. Open the rear cover.
  3. Fold in four a piece of letter-sized plain paper.
  4. Push in the folded paper until it hits the jammed paper.
  5. If the jammed paper is visible from inside the printer area, pull it out and proceed to step 7.
  6. If the jammed paper cannot be pulled out, push in the folder paper from the rear so the jammed paper is in between the feed rollers.
  7. Pull out the folded paper and close the rear cover.
  8. Power on the printer and confirm that the Alarm light is off.
    The jammed paper should automatically eject.
  9. To resume printing, load the paper in portrait orientation.
Trust this is helpful.
Dec 10, 2010 | Canon PIXMA MP600 all-In-One InkJet...
My Canon mp600 was printing a photo when the error message "paper jammed" came up. I know the paper is in the machine, though I can't find it.What do you suggest?
You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
Also see this:
Issue: Paper is jammed inside the printer
    Note:
  7. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  5. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper won't feed into printer & output slot jam error message
reboot your pc.unplug cables make sure you remove papers jams located at the back of your printer
Jun 24, 2010 | Canon PIXMA MP610 InkJet Printer
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
Dec 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper Output Slot Error Message
When the print head temperature falls, the error is
automatically cleared.
Note:
If the print head temperature exceeds the specified limit
when the scanning unit (printer cover) is opened, the
carriage does not move to the ink tank replacement
position.
Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
5110 ERROR ON PIXMA PRO 9000
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Solution: Removing paper jams MP800R / MP830 / MP530
  1. If the paper tears and a piece of that remains inside the printer, open the scanning unit (printer cover) and remove the paper from inside the printer.
    Note: Be careful not to touch the components inside the printer.
  2. Turn on the printer and confirm that the Alarm light is off.
  3. Load paper back into the ASF.
  4. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
  3. Open the rear cover to check if the paper is jammed.
  4. Pull out the cassette and check if the paper is jammed inside the cassette area.
  5. Stand the printer with the rear side down, holding the document cover.
  6. Press the tabs together and pull the green cover toward you.
  7. Check if the paper is jammed.
  8. Close the green cover and place the printer back to a normal position.
  9. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
  10. Load paper back into the ASF or cassette.
  11. Press <OK> to clear the message and continue printing. If you are printing from an application software, follow the instructions displayed on your computer.
Top
Thanks
Thiru
Jun 17, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Error message
hi silv
just seen this post , if still getting trouble with the printer you can try here - PIXMA MP500 -
type in the ? for results.
riz.
Apr 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
21 people viewed this question
old marine
old marine
