Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak esp-3 printer will not print black - Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
5 Suggested Answers
SOURCE: Replaced printhead and ink cartiages on a Kodak ESP.3
I had the same experience with Kodak when I called to get help with my printer. The tech was extremely hard to understand. After several times of trying to get assistance that I could understand, he hung up on me.I finally got them to send me an additional cartridge to replace the ink I had used trying to remedy the problem. I contacted the company and explained what happened. They have not even tried to contact me.Now it's doing it again. I'm finished with Kodak. I'll just take my chances with another company. Hopefully they will appreciate my business which Kodak obviously doesn't.
Posted on Jun 29, 2010
  • 240 Answers
SOURCE: kodak printer esp 3 black ink not printing good
try lexmark printers because it easy to fix it, encase there's a trouble ..
Posted on May 19, 2009
j0llyc
  • 8 Answers
SOURCE: Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Posted on Jun 21, 2009
  • 295 Answers
SOURCE: my kodak esp-3 printer is printing with a pink
open printer access door.remove printhead and cartridges again reseat both of them.. press copy $ cancel for 5 seconds and wait for caliberation sheet to print.. or if u have connected ur desktop, open kodak home center, go 2 maintenance and click on clean printhead. now see if ur documents are printing properly. if not kodak will replace ur printhead.
Posted on Jun 22, 2009
The black on my Kodak ESP-3 has stopped working
The black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the print then a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
Oct 21, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp c315 not printing black
I had this exact problem and was able to fix it quickly. My black would not print or was printing lightly.
1) Open the printer and remove the black cartridge
2) Saturate a cotton ball with alcohol
3) push the cotton ball into the small pad/screen where the ink goes
4) wait a few seconds then replace the black cartridge
5) run maintenance app and do a cleaning then a test page
In my case this cleared up the problem quickly and without a lot of mess or dis-assembly
Mar 04, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3 printer wont print black data. Just changed the ink, both black and color. do I need a new print head or holder? from what I have been reading, there are lots of folks with this problem.
There are various tips for solving the printer problems in Microsoft Office 2010. These problems with the printer may occur due to corrupted drivers installed for printing. Compatibility may be one of the causes. So, users may have to fix the problems by replacing the drivers. Also, remove all the malware infections.
Mar 24, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 5 will not print in black anymore. It had a 3/4 full black cartridge in when it stopped but I installed a new one to to make sure and it still will not work. I have used all of the self...
Sounds like print head needs replacing, try the troubleshooting guide on Kodak website, appears to be a common problem with these Kodak printers, if new it should be covered under warrenty although if not they are expensive
Jan 07, 2011 | Kodak ESP 5 Printer
Purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Jul 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
May 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak ESP 3 all-in-one printer will not print
you may try to clean the printhead and recalibrate the printer. if this will not correct the problem, you need to replace the printhead. I suggest contacting Kodak technical support to have a replacement printhead.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3 printer won't work
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Aug 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Let me know.
Cheers, Chris
Jun 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak printer esp 3 black ink not printing good
May 19, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
2,042 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
