Question about Krups GVX2-12 Electric Burr Grinder
Krups GVX2-12 grinder - ground coffee and container full of static so coffee sticks all over, including inside the container. Any ideas?
    Genius:
  • 1,036 Answers
Most plastic products contain enough carbon black to neutralise this problem. Obviously not with yours.
Try a camera accessory cleaning cloth - specifically anti-static.
http://www.amazon.co.uk/gp/product/B00006IVV8?ie=UTF8&tag=shopwiki-uk-21&linkCode=as2&camp=1634&creative=6738
Cleaning less often will also help, and maybe a quick brush out would result in less mess.
Natural fibres like cotton cloths or bristle brushes will also help.
Coffee naturally has oils that, if left on, will eliminate this problem anyway.
Posted on Feb 07, 2010
Testimonial: "Thank-you - unfortunately, reviews I've found about this coffee grinder indicate that it's a common problem, but your suggestions has helped some."
Grinder spins. Hopper is full of beans. Why is no ground coffee dispensed?
You will probably find that the grinder is bunged up with grounds. This can happen if there is a bit too much steam inside the housings. The grounds bind together and will not drop with gravity. Pull the grinder apart, clean it out then run it with the top housing off and see if you can observe any leaks/steam. There will be some steam, you are looking for excessive steam.
Sep 13, 2015 | Miele CM 5200 Espresso Machine Black
What do I do when coffee beans not getting to grinder
They cannot "not get to" the grinder, the hopper is mounted directly above the grinding teeth. The grinder is probably blocked and you will need to remover the housings and take out the grinder for cleaning and inspection. Most common cause of grinder blockage is dampness inside the housings from a leak somewhere inside the machine.
Jul 21, 2014 | Krups EA8250001 Espresseria Full Automatic...
Why does ground coffee not go thru shoot
If using Beans; it is set to fine and due to static it sticks - OR you have a blockage..
If you are putting ground coffee into a grinder; the static will be a bigger issue and in addition there is no weight from the beans to press the grinds into the burrs. A bean grinder is not ment to grind beans that have already been ground.
Get a better grinder and do not buy supermarket beans.
May 31, 2014 | Capresso 560.01 Infinity Burr Grinder,...
EA6935 krups powdered coffee inside grinder and coffee grounds noncompact
You will need to pull the grinder apart & clean it out. Most likely cause of the grinder blocking up is a leak somewhere inside the machine dampening the grounds as they exit the grinder. They bind up, won't fall out and there is your blockage. You will need to find and fix the leak, there are many, many places for the leak to be, it's a job for a Krups Service Agent. I have outer housings with cutouts in them so I can run them and look inside at the same time to find those troublesome leaks.
Feb 28, 2014 | Krups Coffee Makers & Espresso Machines
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
Krups burr coffee grinder - When I push the power button it flashes on briefly and then stops. It has briefly ground some beans so it working to some extent. Any ideas what is causing the grinder to...
Empty the grinder and see if it will run with no coffee bean in it. Some times debris will get caught in the grinder because it got mixed with the beans from the factory. If it runs your good to go. If not then the mother connection are not solid and it will run off and on at will.
Oct 14, 2013 | Krups Burr Coffee Grinder
Coffee doesn't fall in bag (bunnomatic G1 coffee grinder)
keep clicking the De-chaf lever on the right. This tamps down all the loose grounds. Static is common with coffee due to the low humidity of the grounds (even here in Hawaii) try attaching a small metal chain to the grinder case with a used coffee clip on the end of the chain to attach to the empty bag. This will help it 'ground' out the static to the case.
Feb 10, 2010 | Bunn -o-matic G1 (1 lb. Bulk Grinder)
I bought a Krups GVX2 coffee grinder and am not able to get it to work. I have followed the instructions "to the letter" but once it's plugged in and switched on, the "on" switch on...
I know that this machine is sensitive with the lids needing to be securely fastened (both the top and the plastic catch bottom container) maybe that is it.
Jul 14, 2008 | Krups GVX2-12 Electric Burr Grinder
I have a 12 month old KRUPS XP7240 coffee maker. It has just ceased to grind the beans. I suspect that the grinder or hopper to the grinder is blocked? Any suggestions how it might be...
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
May 19, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups GVX2-12 Electric Burr Grinder Logo
804 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
