Question about Acer Aspire 4315 Notebook
E system 3103 there a line on the laptop screen with xp when put it to a monitor it not there the line
  • 1,675 Answers
Try reducing the resolution as a TV uses a differnet one, try it at 800x600 to start and work your way up till you loose the bar again then go back down one resolution, hope this helps
Posted on Feb 07, 2010
Vertical strip of flashing horizontal lines on Acer Aspire 7551G screen
More than likely it's the lcd screen and will have to be replaced. I could be the video card, but most likely the lcd screen especially when you can put pressure on the screen and cause changes. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok, then the problem is with your lcd screen and the video card is ok. If the Borrowed monitor displays the same as your lcd screen then the problem is with your video card inside the computer.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Once you narrow it down to the lcd screen as being the problem you might try taking the lcd screen apart to reseat the lcd cable on the back at the top of the lcd. Just unplug it and plug it back into the connector. You can also try doing the same where the lcd cable plugs into the motherboard. Just pull it out and put it back.
May 31, 2012 | Computers & Internet
There are faint horizontal lines going up and down my new ViewSonic Monitor screen. I have checked the refresh rate and it is on 60. I have an older laptop with Windows XP. Would this make a difference?...
Hello and Welcome to Fixya.
Few of the top reasons for causing these "lines" running across the screen are :
  1. Corrupted video driver
  2. Changes in hardware configuration (display)
  3. Monitor issue (hardware)
In order to determine if it's hardware/software issue, all you need to do is to boot to BIOS and check if the problem replicates. Depending on system, you can go to the BIOS screen by tapping "F2" or "DEL" key repeatedly as soon as you turn on the computer until you see a different screen.
If the problem is present while in BIOS, then definitely the monitor needs to be repaired by an authorized repair center. Otherwise, video driver update or Operating system re-install can resolve this problem.
Thanks for using Fixya
Apr 12, 2011 | ViewSonic VX2235WM Monitor
Thanks "aaarwind" Sorry I havn't
THe screen on your laptop is faulty by the sound of it as the same processor is used for VGA out as the internal screen.
Check the cables and connectors to your screen before replacing it.
Consult a Toshiba Computer agent for confirmation if you are not sure.
Jan 20, 2011 | Toshiba Satellite P35-S6292 Notebook
My daughter`s laptop e-systems EI 3103 boots up but nothing on screen, all buttons light, keyboard works, if you hold it a certain way you can just make out the password box to sign in, any ideals of what...
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Sep 06, 2010 | Computers & Internet
I think I need a sound driver,I have no sound apart from the beeps.I have no clue where to download a driver and if it is that I need one.Can anyone help me please.I have a E system EI 3103 laptop,with...
You need find out who manufactured that piece of hardware and contact the manufacturer for the driver. Unfortunately that requires taking the system apart. Good Luck.
Aug 05, 2010 | Computers & Internet
Green vertical line on LCD screen
Is this on a monitor or on a laptop LCD display?
Most of the time it is due to a hardware issue like a video card or the screen itself.
When does the line appear?
A. Is it there even with the monitor or laptop turned off?
B. Is it there during the OS logo / boot screen or does it appear after the OS loads?
C. If it is a monitor, with your system turned off go into the menu of the monitor by using the buttons on the front. Is the line there?
What you can do to try and fix it is.
1. Make sure you have all the latest drivers for your video card.
2. Change the resolution of the screen.
3. Change the frequency of the monitor.
If these do not fix your issue you may want to look at getting or borrowing a video card and replacing it if this system is a desktop. If this system is a laptop and the above does not fix the issue your best bet would be to put up with it or buy a new laptop to be honest.
Jun 19, 2009 | Acer 22" X223w LCD Monitor
Ei-3103 vista drivers needed
download AC97 sound driver for vista and realtech ethernet driver for vista these are the to most common,  and install them
May 04, 2009 | Computers & Internet
How to repair the laptop screen
i think is not the upgradation problem may be screen only , connect external monitor and check if it ok, problem in laptop screen
Mar 27, 2008 | Computers & Internet
Acer Aspire 4315 Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
