Question about Mitsubishi VS-7083 70" Rear Projection Television
MITSUBISHI vs-7083 i recently came up on a MITSUBISHI vs-7083 tv i dont have the manual and have a uneversal remote i dont seem to get eny channels when i go to the menu the channels come up on the little screen that comes up i tryed programing the channels but still nothing only on that little screen when i go to the menu tryed the 3 difrent inputs on back oh also no sound at all from channels just a little statick
  • 3 more comments
  • jorge_o Feb 22, 2008
    Cox digital cable
    Cox digital cable
  • jorge_o Feb 26, 2008
    i got it fixed it had to do with the "USE HOME THEATER" button thank you enywayz
  • Anonymous May 21, 2009
    i have the same problem but i cannot turn off the home theater option. it says i have to hit the cancel button but my Universal remotes. none of them have a cancel or home theater option..
  • Anonymous Mar 17, 2014
    Am trying to program my tv without the remote I only have 12 channel program I want to program the other channels
  • 979 Answers
What is your source? Antenna, cable, or satellite?
accordianman
Posted on Feb 22, 2008
  • Michael Borelli Feb 23, 2008
    The only channel you'll be able to see is the one that your cable box puts out; either ch 3 or 4...accordianman
Tv tuner dk whats going on?
Yes, you can play DVD movies on TV, you need the tuner if you want to see broadcasted channels.Your universal remote should have codes for Mitsubishi Rear Proj. Tv's. If you dont have the instructions with the remote , call the manuf. Good luck!
Nov 13, 2013 | Mitsubishi VS-50609 50" Rear Projection...
RELENTLESS SNOW
You shouldn't have to have the tv to channel 3 or any other for that matter if you are in component. You need to make sure the tv is on the component input from your display menu that can be accessed from your remote.
Nov 12, 2013 | Mitsubishi VS-60805 60" Rear Projection...
Stk part number for vs-7083
model not listed--sure it is not a VS-70803?
That model uses the 392-040 chips and for that matter you can look inside to confirm the number right on the chips.
Jun 07, 2012 | Mitsubishi VS-7083 70" Rear Projection...
Vs-7083 what stk part number does it need
These STK's work for your model.
STK 391-020
STK 397-010
I have a Mitsubishi vs-4543 tv that when powered
check the power supply section.. probably the electronic component got problem.
Jun 04, 2009 | Mitsubishi VS-4544 45" TV
1995 mitsubishi big screen vs-6041
I have a copy of the owner's manual for my 6041. If you would like, I can scan it and email it to you.
--Ralph Dowling
plaintiff@comcast.net
Feb 02, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi diva cant tune in
well .... no online user manuals for thoseTVs
you will need to use a digital seck top box and use that units remote to tune the TV
if there are any (needs a user manaual)
use the buttons on the TV lower casing
to tune up
none of the all in ones remote buttons work for all TVs functions
you are lucky if it turns on and off
and changes channel
Apr 29, 2017 | Mitsubishi VS-45609 TV
Mitsubishi VS-50703 blurry after move
A halo effect usually means the coolant in the CRTs need replacing in the effected color usually blue goes first followed by green. red seems to be less prone for some reason.
Jan 14, 2008 | Mitsubishi VS-50703 50" Rear Projection...
Mitsubishi TV Model VS-7083
The deflection board and/or smps have most likely ring-cracked on one or more components on the board due to heat stress. It's not an expensive fix at the moment, but continuing to operate it this way will place additional stress on components like the regulator and they will eventually fail...
If you're taking it into the shop for this repair also discuss with your tech to do the following per Mits bulletin: APPLY FOLLOWING CIRCUIT CHANGES ON PCB-SIGNAL: A. REPLACE R2K8 WITH A 1K RESISTOR (BASE OF Q2B2). B. REPLACE R2K3 WITH A 47 OHM RESISTOR (IC201 PIN 50). C. ADD A 100PF CAPACITOR FROM BASE OF Q2B2 TO JUNCTION OF R2L0 AND R2K6 (GROUND).
Have a great day!
Bill
Nov 29, 2007 | Mitsubishi VS-7083 70" Rear Projection...
Televison & Video Logo
188 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
