Question about Akai LCT2060 Television
I have an Akai lct 2060, i plug it in it works fine for while, then it randomly turns off, indicator light on the power supply which is usually on green goes off as well
  • jharo932 Feb 07, 2010
    other notes to have, i have two of these sets, but i only have one ac adpater to both of them, one got lost in a move, and they both do the same thing, could it be the adapter?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board we’ll need to check few things. When you open the unit up; take a look at the power board-the board where, the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all he inputs are going into. Also check for the Backlight Inverter Board if the sound is coming fine from the TV however as its shutting off so it should be either the power board or the main board. All this is only recommended if you have electrical expertise and know how to solder/re-solder components.
. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
AKAI LCT 2060 was working well as a TV. Just hooked it up to my PC and the message on screen reads "No Signal" Checked monitor cable and it's good. checked old monitor and it works well. Why...
The display settings on your computer need to be turned down. Set it to 800x600 and move up from there, if the resolution is too high - the TV won't display it.
Feb 28, 2011 | Akai LCT2060 Television
Akai LCT 2060 TV will not turn on. Power unit shows blinking green light, but no picture.
Click HERE to download service manual copy as it was promised in chat session.
Thanks.
Jan 07, 2011 | Akai LCT2060 Television
I have a AKAI LCT 2060 TV, cannot see picture, only sound
This problems,i fix alot models of tvs all diffrent models of tvs but have the same board alway dies.The LCD inverter board is dead.This board help the LCD to have a backlight to go through the Turner board to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.The board is long in shape.It the easiest board to replaced in LCD tvs.
May 07, 2010 | Akai LCT2060 Television
Problem with akai lct 2016
you can buy the new power supply on ebay for less then $20
Aug 28, 2009 | Akai LCT2060 Television
Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Jul 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Akai lct 2070 tv switch does not turn on tv-no sound-no tv
Most failures on this TV are due to defective power supplies. If the TV does not turn ON, you should replace the power supply.
Check this website to buy the power supply adapter and hopefully that should fix the TV.
Jan 21, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Akai LCT 2701 TD - Red Blinking lIngt
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Jul 08, 2008 | Akai LCT2701TD Television
NEED AN OWNERS MANUAL FOR AKAI LCT2060 My Tv.not have power
hola nesecito el modelo del boar el tv es akai lct 2060
Jun 07, 2008 | Akai LCT2060 Television
Akai LCT 2662 will not turn on
I'm surprise to see the repair shop telling you there nothing they can do.
The power supply can be fix if you take the time to troubleshoot it. However this is not a DIY project.
The failure is in the capacitors that are bulging out of the top or bottom. Quite visibly defective.
4- 3300uf @35V
8- 2200uf @25V
7- 1000uf @10V
1- 1000uf @6.3V
3- 100uf @25V
Feb 27, 2008 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Akai LCT2060 Television Logo
66 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
