Question about Whirlpool Duet GHW9150P Front Load Washer
Duet front load rubber gasket in between door and tub starting to twist how do i prevent this from happening
  • davebook66 Feb 07, 2010
    is it possible that the gasket could be rubbing on the tub it is twisting in the counter clockwise motion
  • 572 Answers
Ur loads. might be too much.
Posted on Feb 07, 2010
My grey rubber gasket around the tub has a 1" rip in it. This is located where you open the front load door and on the grey rubber gasket just inside. Is there a patch kit? Or do I have to replace...
I search on google and no such patch kit. I tried a bike inner tube repair kit and it seems to work, but my holes are less than 1". Check out my post. I have a gasket on the way just in case.
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Something is making a screach sound like a nail or screw rubbing on the barrel how can find it?
I would first look under the door rubber gasket or in the tub to see if maybe a coin, or screw has fallen out of a pocket. I've had this happen several times even though I check all pockets before using my washer. It may not be easy to locate so you have to search every inch and pull back the rubber.
Aug 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Extreme mold on the gasket. How do I remove the mold and odor?
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!@
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Mold on the gasket of kenmore duet front loader. have run the clean cycle, and scrubbed the gasket and inner liner also
This is a common problem with front loading washers. To prevent this issue leave the washer door slightly ajar after use. It will promote air circulation and prevent mold.
Oct 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet ghw9100lwi inside gasket on tube is wrinkled - what could have happened -is that what they call gasket, tube in the scamatics? and is that what they are referring to as a bellows gasket on this site?
If you are referring to the wide gray rubber bellows gasket that goes between the outer body of the washer and seals to the outside of the drum (fits to the washer's window when door is closed), it can get wrinkled or skewed if something gets caught between it and the door and a load is run. Mine did this years ago (and in fact ripped slightly) when the corner of a pillow got trapped, then a cycle was run
You can fix this fairly simply yourself, especially if the gasket is intact. Look around the outer edge of the machine (where the gasket intersects the front panel) and you'll notice a wire clamp that holds the gasket in place in a trough on the front panel. Follow it around until you find the end of the clamp. As I recall, there is simply a wire oval holding the ends of the wire clamp. Use a vice grips or needle nose plier to compress the ends of the clamp, then remove the fastener and the clamp itself. Readjust the gasket so it is straight (there is a small hose coming through at the top of the gasket for orientation) and reverse the steps to reassemble the clamp.
Hope this helps! Sorry if it seems a little vague, but this is all from memory
Oct 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I've had my Whirlpool Duet for a couple of years now and in the past 6 months or so, I have noticed when I open it after it sits empty it smells sour like water isn't pumping completely out. I have checked...
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi--I love my Whirlpool Duet washer, but how do I clean the door gasket and get rid of the mildew and mildew odor?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((())))
Sep 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is ripping my clothes
yep, I have that problem too. My son's winter coat got wripped to shreds.
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Gasket came loose and rapped around laundry-tub seems loose
if your metal ring (clamp) came off it is most likely due to you shocks or the spring at the top are worn out and need to be replaced. this will happen more often if the cycles are off balance or the washer is over loaded
Nov 26, 2008 | Whirlpool GHW9400 Front Load Washer
Washer is leaking
Check the rubber bellow (gasket) around the door. This is the symptom of a door gasket that it starting to leak. Pull the rubber folds back and check the area where the gasket attaches to the wash tub. You may have a crack or tear. If the gasket is worn please replay back to this post and I can give you advice on how to replace it and where to get a replacement gasket.
May 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
232 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
