Question about Miele Dishwashers
Intake/Drain light is on. First flashed F13. Cleaned the water intake filter;cleaned the triple filter and drain pump.Light continues to stay on-it seems as if no water in coming in the dishwasher. Water supply is on all the way.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F13 is a flow meter error; unfortunately there is no way to reset it so you’ll have to get it replaced. It is recommended to get this done by a repair man as it’s a kind of complicated job. You can call them up and check for local authorized centers. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
My miele g680 dishwasher did have a flashing intake/drain I cleaned it seemed to be working fine, then everytime I try to start it the softener light comes on with no further washing activity.
that is just an indicator that your salt is low. it will stay on until you refill the water softener with softener salt. it will not affect the dishwasher to run it without the salt. the water for your final rinse will not be softened.
Apr 06, 2012 | Miele Dishwashers
Hi, My Miele G 2140 dishwasher bought five years ago just stopped working. It works until the Intake/Drain step of its cycle, then stops midway completely and the Intake/Drain light flashes. There is water...
Hello well you sure have the top of the line unit. You will have to pull it out and turn it over and remove the water pump and check for blockage the impeller should move when you turn it with your finger if not then replace the pump.
Sep 26, 2011 | Dishwashers
Red intake light comes on and dishwasher will not drain, model g 843 scvi
The manual is available here: http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models . Scroll down through the list to the G643 G843 Incognito. The maintenance items listed below are detailed on page 44 and beyond of the manual.
The Intake light is also the Drain error light. If the light is flashing, then turn off the dishwasher and clean the triple filter, the drain pump and the non return valve and make sure that there are no kinks in the drain hose.
Make sure the water is ccoming in at a pressure above 4.5 psi. Also make sure that the water valve is open and clean the water intake filter.
The final possibility is that the Waterproof system has tripped and you need a Miele technician to service the unit.
I hope this helps.
Feb 19, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Drain intake indicator flashing. We have cleaned all but the intake filter. How do you clean or check to see if cleaning is necessary of the intake filter?
After cleaning the drain, looking at the intake (no filter on ours) and the light wouldn't go off, I just decided to take the ctrl-alt-delete approach and hit all the lower four buttons all at once, bingo, it cleared the light and machine started.
Sep 25, 2009 | Miele Touchtronic G892 Built-in Dishwasher
Hello , The inlet/drain light on my dishwasher is flashing , I have mislaid the manual can you explain how I can rectify the problem please , I am assuming something is blocked. Regards Georgina Cooke
My G892SC is almost 10 years old and recently had the same problem. The machine seemed to be stuck in the drain cycle and the intake/drain light flashed. I called Miele and ran through a few diagnostic tests but nothing worked. I had a Miele certified technician come out to look at the problem and he told me the drain pump needed to be replaced and that it would cost about $500 for the part and labor. While researching the cost of a new dishwasher, I stumbled on some online discussions about this problem and someone suggested pressing all 4 lower buttons on the control panel at the same time. I tried it last night and it worked! I only ran the wash & hold cycle but will try a full cycle tonight.
Jun 24, 2009 | Miele G892SC SS Dishwasher
Intake/drain light flashing
I have (had) the exact same problem with my Miele. Here is what (appears) to have fixed it:
1) Disconnect the inflow line at the water source. Its the connection that looks like a garden hose. Use a screw driver to remove the washer inside, the pull out the little filter with needle nose pliers. My was clogger with particles from the washer. Clean with soap and a tooth brush.
2) Disconnect the outflow line at the garbage disposal. My was moderately clogged with food (Note: my son overfilled the garbage disposal before running. It may have backed up).
This worked for now at least. Remeber, as irritating as red lights can be, it prevents the motors and pumps from burning out when you have clogged plumbing.
Kerry
Mar 10, 2008 | Miele Dishwashers
Intake/Drain red light comes in and shuts down during wash cycle
I had the same problem. Switched to powder detergent instead of liquid and the problem was solved! Hope it works for you.
Nov 11, 2007 | Dishwashers
Dishwashers Logo
319 people viewed this question
Top Miele Dishwashers Experts
Mike
shaun taylor
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
