My sony KP-51ws500 51 inch rear projection TV's timer/stand by light is blinking 5 times, then pausing, then blinking 5 times again, what is the problem? I got the Tv from a neighbor that is moving lastnight. we unplugged it and carried it up the street to my house last night
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. 5 blink error code White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. This happens when no raster is generated, CRT cathode current detection reference pulse output is small. If you have electrical expertise and know how to solder/re-solder components then this can be done by you, if not then it is better to contact a professional. The cost of repair should be around $300 including labor depending on the parts that have gone bad. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 07, 2010
TV turns red,shuts off, stand-by light blinking 8Times
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Feb 27, 2014 | Sony KP-51HW40 51" Rear Projection...
Timer/stand by light is on but no picture. Un plugged and plugged then the light blinked but still wouldn't turn on.
How many times does the led blink in between pauses? Thats an error code if it repeats a blink sequence.
Mar 28, 2010 | Sony KP-65WS500 65" Rear Projection...
Problem for Sony KP-57WS520 57 in. Rear Projection HDTV-Ready... Stand by light flashing, TV will not turn on
need to know the number of blinks as thats an error code. it should blink a series of blinks pause briefly then repeat the sequence.
Nov 23, 2009 | Sony KP-57WS520 57" Rear Projection...
Sony tv suddenly turned off with the timer light blinking ,and it cannot be turned on again
How many tomes is the timer blinking? It should blink a certain number of blinks pause briefly then repeat the process.Thats an error code
Nov 23, 2009 | Sony KP-51WS500 51" Rear Projection...
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
No picture on sony rear projection
How many blinks is it blinking before it pauses? Let me know your set is going into protective shutdown. It should blink a number of times then pause for a second, then blink again. Try to count the blinks in between pauses. Then let me know
Jan 20, 2008 | Sony KP-46WT500 46" Rear Projection...
Front panel timer/stand by blinking light
did you clear the code by hitting display channel 5 volume up then power then press 8 enter or look at sony blinking codes to reset to factory settings
Sep 10, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
