Question about Canon Cameras
When I turn power on on my S500, I hear clicking sounds and it appears that shutter is releasing itself quickly. I am unable to use zoom and when I take pictures, I see horizontal lines.
  • 20 Answers
Your camera calls for a servicing.
Posted on Feb 17, 2010
Doesn't start, clicking sound in lens assembly, any solutions?
  • try connecting the unit directly to the adapter or power source . batteries might also be poor and unable to open the lens. if it still don't work then there might be a mechanical problem with the lens have it checked at the nearest service center
Aug 23, 2014 | Panasonic SDR-H85K Camcorder - 80GB - 78 x...
Canon Powershot A1000-IS stuck on zoom plus shutter problem.
hello. If there is a reset, it will show it here in the manual. go to this web address. http://gdlp01.c-wss.com/gds/0300001222/PSA1000IS_CUG_EN_02.pdf hope this helps. Ron
Sep 08, 2009 | Canon Powershot A1000IS Digital Camera
Camera turns off when shutter button is pressed.
[source]Question about Samsung Digimax S500 Digital Camera[/source]
Try replacing batteries (high Ah photographic type).
The lens motor & electronics may be draining power if Ah capacity has dropped too low. At night, it could be that your flash is trying to fire (another drain), or shutter timer / mirror staying open longer.
Sep 20, 2017 | Samsung Digimax S500 Digital Camera
E 18 problem
The E18 error happens on Canon cameras usually when the lens is jammed when extending.
The error is so (in)famous that it has it own website where you can find help and advice on how to fix it. You can view the site by clicking the link underlined in blue below:
http://www.e18error.com/
There is also a Wikipedia entry which you may find helpful:
http://en.wikipedia.org/wiki/E18_error
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Aug 02, 2008 | Canon PowerShot S500 IXUS 500 Digital...
Stuck shutter D100 Nikon
The R06 is the buffer indication, not part of the error. It would appear more work is required. Other components may have failed, or the shutter itself may be bad.
I'm afraid this one is not a DIY. Nikon is pricey on repairs, you may fair better checking the repair service search here on Fixya.
Mar 31, 2008 | Nikon D100 Digital Camera
Samsung S500 beeps and turns off when i hit shutter
If the Olympus is using the exact same batteries as the Canon, there is a high chance that the problem is with the batteries.
Dec 13, 2007 | Samsung Digimax S500 Digital Camera
Frozen lens and shutter
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 06, 2007 | Canon PowerShot A510 Digital Camera
Video Problems
Auto Mode In this mode, all you have to do is press the shutter button and let the camera do everything else. 1. Turn the camera on.
2. Turn the shooting mode dial to normal_mode.gif.
mode_dial.gif 3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
  • The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
  • When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
  • Two beeps will sound when the camera has finished metering, and the indicator will light green or orange. If the LCD monitor is on, the AF frame will appear green.
  • The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
af_frame_indicator_a70.gif 6. Press the shutter button all the way.
  • You will hear the sound of the shutter when the shutter activates.
  • The picture appears for two seconds on the LCD monitor, if it is on.
  • The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
Jun 10, 2007 | Canon PowerShot A400 Digital Camera
Zoom error
I had the same problem with mine and I tried several suggestions, BUT the only one that has worked is to gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur. Another note. I had tried this several times until I finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Dec 09, 2005 | Fuji FinePix E550 Digital Camera
Cameras Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
