Question about Kenmore 62602 Electric Dryer
I just replaced the dryer element in my Kenmore dryer and also the heat fuse. I have no power when I plug it in.
    Genius:
  • 1,122 Answers
You should check the door switch,powercord connection,and main fuse on the blower box-mike
Posted on Feb 08, 2010
HE3t Kenmore dryer runs fine but suddenly stopped producing heat
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 31, 2009 | Kenmore Dryers
No heat gas kenmore gas dryer
Kenmore heavy duty. its working properly but not heat
Power from the house:
Heating element:
Thermal fuse:
Wiring : A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
thanks and keep updated.
Jul 08, 2009 | Kenmore Dryers
My Kenmore electric dryer runs but no heat ....
Before I wish you luck i want you to review all of the possible reasons for your problem
Heating element
Thermal fuse
Wiring
May 29, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer
Hi!
Heating element
Thermal fuse
Wiring
Heating element
Thermal fuse
Wiring
Do rate the solution as FIxya if you find this solution helpful.
Thanks
Rylee
Mar 15, 2009 | Kenmore Dryers
My Kenmore Dryer (GAS) heats for awhile then stops heating.
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Dec 08, 2008 | Kenmore 73952 Gas Dryer
Kenmore Elite dryer
Heating element
Thermal fuse
Wiring
Hope this may help;
Rgards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Kenmore 63942 Dryer
Dryer won't heat
Heating element
Thermal fuse
Wiring
Aug 11, 2008 | Kenmore 74832 Gas Dryer
Kenmore dryer doesn't give off heat
Heating element
Thermal fuse
Wiring
Jun 15, 2008 | Kenmore 73952 Gas Dryer
72602 kenmore dryer
Heating element
Thermal fuse
Wiring
Apr 28, 2008 | Kenmore 72602 Gas Dryer
Kenmore 62602 Electric Dryer Logo
59 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
