Question about E-Machines eMachines Desktop PC
Power suply the computer wont turn on - E-Machines eMachines Desktop PC
  • joecoolvette
    joecoolvette May 11, 2010
    Do you wish to check the Power On switch first? Then check the Power Supply? The Power On switch is checked by bypassing it using a jumper wire. The Power Supply is checked with an economical power supply tester, (Also with using a jumper wire to turn the Power Supply on), or using a known good, compatible power supply for a test unit. One example of a power supply tester,http://www.tigerdirect.com/applications/... Or, do you just wish to know what power supply is compatible, with your eMachines desktop computer for a replacement? If so I need the Model Number from the back of the computer.
    Problem Solver:
  • 8 Answers
If the power supply is a Bestec ATX-250-12e then most likely the power supply has killed the motherboard. You will have to replace both the power supply and motherboard.
Posted on Jul 20, 2010
    Sniper:
  • 79 Answers
The smos of the comp might have gone bad
Posted on Feb 08, 2010
Dell latitude 10 st2 e wont boot
Hi voyagerbooks,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30 sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check if the computer gives any series of beeps or if there are any diagnostics LEDs shown on it.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Apr 07, 2015 | Dell Computers & Internet
Gateway dx 4320 wont turn on
It could be a few things:
a faulty power switch - you say that you've changed the PSU, but did that include the switch?
it could also be a Faulty Motherboard or CPU. If either of them are fried, you won't see anything come on either.
I'd suggest checking the switch first because that's the cheapest and easiest to replace
Sep 14, 2012 | Gateway DX432019 PC Desktop
Wont turn on
If your computer is in a loop boot the problem is clearly the chipset, but before being sure of it you have to disconet the memory cards and to change themfrom the slot try one at the time in slot 0 if the problem continues then 80% for sure is the chipset that needs to be changed. If your computer does not turn on then the problem is power suply, check the power suply inn maybe it is defectuose, or the starting capacitor is defective, hope tou solve the problem
Oct 22, 2011 | Acer Aspire One PC Notebook
When pressing start button the machine starts but only runs for 1 second. the led lights up the message (turn on power supply)
this souinde like your power suply switch is turned off. if you look on the back of your computer were the power cord goes into the computer thats your power suply. if you look closly there is a switch on there this switch proble got shut off. you wanna make sure it is turned on.
Jan 07, 2011 | HP Compaq Evo Workstation W8000...
My vostro 200 slim tower wont turn on PLZ READ FULL
There could be a hardware problem on the computer if the power button led light is "Orange/ or amber", if you can open the computer, try removing one memory card at a time and see if the power button will change.
Dec 15, 2009 | Dell Vostro 200 Mini Tower With 20" Flat...
Powers down
get a bigger power supply
Jul 29, 2009 | Alpine CDE-7826P
It wont start up or turn on
This would be your power supply causing this - It's not putting enough power to the motherboard. Change out the power supply, and your problem will go away.
Mar 12, 2009 | Compaq Presario SR1000T (568657) PC...
Doesnt turn on anymore.
Hi..there,
It's seems your backlight inverter is burnt out... need to be replaced with a new one or you can repaired yourself by testing all the capacitors to see which it has been burnt out or has a leaked. After that just replaced the bad caps... Good lucks, Have nice a day!
Aug 16, 2008 | Fuji FP-988D 19" Flat Panel LCD Monitor
Computer won't turn on
hi
check your power cable , eathing. smps check *********** bord dont touch the cabinet.i think u have motherbord grounding or your power suply of pc has pro.
Mar 20, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
105 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
