My computer keeps shutting down when i plug my apple ipod in to it i have a error report which states blue screen error caused by a device or driver i have reset my computer and had it re programmed but the error still occurs
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 61 Answers
Get your motherboard re-burnt
Posted on Feb 08, 2010
My ipod says DISABLED CONNECT TO ITUNES
Sometimes when you connect your iPod to the computer it will do nothing.
If that's the case...keep the device plugged in and do a hard reset.
Hard Reset: Hold down the power button and home button at the same time, the device would completely shut down (Do Not Let Go) next you will see a apple symbol (Do Not Let Go) it will shut down once more and a few more seconds it will have the symbol to connect to iTunes (Now you can let go)
Restore the device as prompted on the screen.
There are times when a Hard Reset would be needed more than once.
Jun 28, 2014 | Apple iPod touch
How do i reset an ipod
Step 1:
There are many iPods each having there own specific method of restore them WHAT MODEL ? The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo. This error error occurs when the hard disk is unable to access the information and stalls while opening a file. A reset of the device usually corrects the problem, as it clears the device's memory and any errors. Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch. Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position. Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel. Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo. Plug the iPod's connector cable into the dock connector on the bottom of the iPod. Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod. Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu. Click "Eject iPod" in the sub-menu to disconnect the device. The iPod takes four hours to completely charge its battery.
Feb 17, 2013 | Apple iPod Audio Players & Recorders
My ipod wont turn back on
You have not stated any model no. which makes it hard to provide a solution.
Hope this helps.
Jan 24, 2013 | Apple iPod Audio Players & Recorders
REBOOT IPOD
which model ipod they all have different ways to reset usually through iTunes
Hope this helps.
Jan 20, 2013 | Apple iPod Audio Players & Recorders
HOW TO UNLOK THE A1136 IPOD
click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
right click select rename to open or delete the folder your Ipod should now be open
or you might do a factory reset
hope this helps
Oct 18, 2012 | Apple Ipod Video 5.5 Gen Black 30gb Mp3...
hope this helps
Oct 18, 2012 | Apple iPod MA446LL/A MP3 Player
.my ipod is disabled... how
Hi, just Hold down the home key and power key then plug the cord to your ipod to the computer then get on itunes and restore it
Also i am going to show you how to fix the semi-common ipod error that renders your Ipod unusable. Until now!
hings You'll Need:
* Computer w/ itunes
* Ipod touch or Ipone
* USB Cable for either device above.
* Your fingers (preferably your thumb)
Instructions
Start-up your computer and log in. Open itunes and leave it on the screen.
Now, hold down the lock button on the top of your device until the power off slider appears. Slide the arrow to shut off your ipod.
Now plug the USB cable into your computer. Make sure that the Ipod is not connected yet!
Hold down the stop button on the device and plug the USB cable into the device. Keep holding the stop button until you see the USB cable with an up arrow into an itunes symbol appear on your screen. This means that the connection to your computer was successful and that you are in recovery mode now.
Now click ok, and download and install the latest Operating System to your Ipod. You will lose all of your data on this device, so once you are done you have to re-download everything.
That's it. Now your device is working again, and it has the latest OS. It will be super quick, and all you have to do is restore your songs, apps, and other data and you have a good as new device!
Good luck...
Mar 02, 2011 | Apple iPod touch
Computer shuts down when Ipod touch is connected
if u have taken any pictures with your itouch delete them and it would solve ur problem...
i had the same problem i deleted them and it worked perfectly fine
Feb 26, 2009 | Apple iPod touch
Blue Screen!
this might be some problem with your registry.. There are plenty of software can chec this.. I suggest you try to look into below link to further understand the registry issue.
http://etech.maiila.com/?p=24
Apr 29, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
