Question about Car Audio & Video
The off set light is on. what does this mean - Car Audio & Video
  • 47 Answers
ITS A PROTECTION LIGHT SO UR AMP DOESNT BLOW SOME ISNT HOOKED CORRECTLY OR SOME THING OF THAT NATURE
Posted on Feb 28, 2010
I have an 05 Suzuki Forenza that has a flashing check engine light. This started on Tuesday. Had the codes looked up. Car is driving shaky and dash lights are blinking. Any ideas?
fix the anti freeze leak --before you blow a head gasket
what your codes mean
Check Engine Light On, P0300 Random Misfire Code. A random misfire means your engine is misfiring, but that the problem is not isolated to one or two cylinders. It is jumping around in a random way from one cylinder to another. A random misfire code usually means the air/fuel mixture is running lean.
What the P0700 code means. P0700 is set when the PCM detects a malfunction in the transmission control system. This malfunction causes the vehicle to set a Check Engine Light and trigger a failsafe mode. Once the failsafe mode is set it will remain until the fault is repaired or normal operation is detected.
PO133 Oxygen Sensor Circuit Slow Response (Bank1, Sensor1)
Nov 25, 2016 | Suzuki Cars & Trucks
My heating blanket is flashing on and off wat does that mean
It means it is probably burnt out at that setting. Try another setting and see if the light stays constant.
Flashing light on any appliance usually tells you it is not working or you haven't completed all steps (like in the case of a coffe maker for example).
Mar 04, 2015 | Heating & Cooling
What do the symbols and dial settings mean on the electrolux diplomat lx
Symbols..Question mark means "Put a bag in me", checkered light means : "Change me, I'm dirty"....pre-lit power light means: "You have Powaaa" to the unit and the thermostat light means the motor is too hot if it comes on, (most likely from a hose clog) and needs to cool down before the motor will run again. The settings on the control valve basically have to do with the auto shutoff when the bag needs changed. The lower the valve is turned, the more full the bag will get until it shuts off. Hope that helps!
Apr 24, 2014 | Electrolux UltraLux 2000 Bagged Canister...
What does "setting aperture" mean?
The "aperture" is the hole inside the lens that controls how much light passes through. The bigger the hole, the more light passes through. Make the hole smaller and less light gets through.
Proper exposure depends on controlling the amount of light getting through the lens to the film or digital sensor. You control it by opening or closing the aperture and setting the shutter to determine how long the light gets through.
Setting the aperture simply means setting the size of this hole to some value.
Jan 08, 2013 | Cameras
The anti lock brake light and regular brake lights are on, in my 2001 mitsubishi montero limit truck what does that mean
First this means you should not drive it until the repairs are done. Your brakes very well may not respond with both warning light indicators lit up. So one light is for your brakes and one is for your ABS system. The ABS light on means there is a malfunction in your ABS system. A sensor or something in the wiring. Now this light on alone indicates the need for a repair but the car could be driven temporarily. The ABS system makes your brakes fluctuate so "locking up" is avoided. The Oil light itself means something in your brake system is malfunctioning and hydraulic compression could be lost anytime. Both together is not good. I recommend first you check the brake fluid in your car. If it is below what it should be then this alone could set the Oil Light on. A brake light out could set your ABS light indicator on as well. So check the two things and if you are lucky this could fix each light. If not then you need to have this addressed by a auto technician as soon as possible.
Regards, Tony
Apr 12, 2011 | Mitsubishi Montero Cars & Trucks
I have a nespresso latissima machine,Got it for x-mas, and now there is constant yellow light on the water (the tank is full, and there is a blue light when it is time to fill it up...) What does it mean?
I just had this same problem with my brand new Latissima premium and I fixed it by adjusting the water hardness setting. The yellow water warning light being constantly on means the machine thinks the water is too hard and the machine needs descaling. In my case, the machine just needed to learn how hard my water actually is. In the manuals that came with the machine you should have been given a ph testing strip and there are instructions in the user guide about how to adjust the water hardness settings. As soon as I did that, the yellow hard warning light immediately went off. In my case the water setting needed to be adjusted to the 7-14 ph setting. I'm attaching pics of the water hardness setting instructions from the manual.dberlyne_3.jpgdberlyne_2.jpgdberlyne_1.jpgdberlyne_0.jpgdberlyne.jpg
Dec 28, 2009 | Nespresso C190 Espresso Machine
I dont know what the telephone light means
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 14, 2009 | Belkin (F5D5231-4) Router
My nintendo wii power light has gone amber what does it mean.
that means its on a mode between off and on, its like a power save mode, there is nothing wrong with it
Apr 17, 2008 | Nintendo Game Boy Advance Console
Car Audio & Video Logo
88 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
