Question about Bissell 8910 ProHeat Clear View Upright Vacuum
My Bissell Proheat 12 amps' brush keeps dragging on the carpet when I go to push it forwards. And it releases alot of water.
Mine is doing the exact same thing..Push it forward and it makes a awful noise. The Brush on the bottem is loose and it isnt spinning. SO i took and turned it over and there is a metal gear like part that runs the belt on the brush. I took it out and cleaned it...basically because it was just hanging in there..not Turning the belt..AND NOW I cant get it back in..I am totally disgusted as it hasnt been used very much at all. I cant get the gear metal piece back in to see if it works.IT Just falls out. and its a bear to get it in there..
Posted on Feb 20, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell proheat 12 amp turbo carpet cleaner, not sucking water, model#8910
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Apr 15, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Whenever I push the Bissell Proheat the brushes catch on carpet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
yrf45
Mar 09, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
How to release and withdraw water solution to clean carpet.
Problem resolved by contacting a local retailer who provided instructions.
Dec 30, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
My Bissell Proheat 12 amp is hard to push forward(whether on or off). There is a loud clicking noise when pushing forward and it ''jumps'' up on every loud click. It's OK when pulling backwards, sprays and...
I had this same problem and here is what solved it for me. On a previous cleaning session, my wife decided to take the two front screws out of the clear plastic shroud that covers the brushes in order to clean behind it. Upon re-installation, she did not secure the top part correctly. On the end near the water tank, there are two tiny half-moon tabs that absolutely need to be seated in their opposing slots in the chassis.This allows for a good seal which enables the machine to **** up the water. It also keeps the front cover level and from dragging on the carpet when pushing it forward. Both were problems I was experiencing. Hope this helps!
Mar 09, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell pro heat advantage 12 amp
You can download the instruction manual at the Bissell.com web site.
Jun 29, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 1698 PowerSteamer ProHeat Upright will not work. The brushes spin, the soap comes out, but no water is getting to the carpet.
You may try the trigger assembly may not be releasing the water , your brushes spin and the soap comes out but no water – it may have come unhooked or broken, also the water line could be plugged, clogged or pinched and not releasing water to the brushes -- you may try the owners manual for the trouble shooting for the item or check the Bissell website listed below or the customer service phone number of 1-800-237-7691 – the website has a list of trouble shooting listed right on the website I you enter the Model number and hit trouble shooting
http://www.bissell.com/
By Phone Customer Service:
(800) 237-7691
Hours:
M-F 8:00 a.m. - 10:00 p.m. ET
Saturday 9:00 a.m. - 8:00 p.m. ET
Apr 15, 2008 | Vacuums
Bissel Proheat 2x "catches" when it is pushed forward-- Help Please!!!!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=499675
Bissell ProHeat 2x "catches" when it is pushed...
Posted by Marlene101 on Apr 08, 2008
My ProHeat 2x bucks and catches when I try to push it forward-help!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Bissell 9500 ProHeat 2X Clean Shot Upright
The Bissell is not designed to be like a vacuum – it is designed to clean on the pull back, you dispense the Bissell cleaning fluid, the brushes scrub the carpet and the suction will vacuum up the excess water, the push forward will do the reverse action. You may want to refer to your owner’s manual and check out the trouble shooting guide for no water coming out. You may want to contact the factory or manufacturer to see if they have service tech support or to send out a new owner’s manual for your current model #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ By Phone Customer Service:
(800) 237-7691 Hours:
Don – The Vac Man
Go Ahead. Use Us.
Apr 08, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Need help putting back together
With out seeing it, it will be hard to figure out what isn't right. Must be a different model then 1699. which model is it?
Nov 08, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
520 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
