Question about Canon i850 InkJet Photo Printer
The same 4 bulk inks
I have a Canon i850 that has failed.
What newer low price printer will use the same 4 bulk inks?
    Problem Solver:
  • 10 Answers
If you have bulk ink and not just the cartridges there is a newer printer that uses the same inks. the cartridges are the pgi220 and cli221 (c/m/y/pb).
the printers that use these cartridges are the Pixma iP3600 / 4600 / MP540 / 620 / 630 / 980
good luck and hope this helps
Posted on Feb 08, 2010
    Scholar:
  • 59 Answers
The bad news: Canon does not make any new printers that use those ink tanks. Their line of new consumer printers is the PIXMA series. None of these printers uses the BCI-3 series of ink tanks. I am sorry for the bad news,.. The good news: I have personally been successful in finding used, operational printers for $1 to $5 from local thrift stores and for a little more at local "Recycled, Used, Computer" type of stores. You may even try craigslist and put out a wanted ad for the models below,... anyway I hope this helps you out.
Here is a list of models that use all of the BCI-3e series of Black and Color tanks
Color Printers: i550, s400, s450, s500, s520, s530d s600, s630, s630 Network, s750, all BJC-3000 Series
Multifunction Printers: MultiPass F30, MultiPass F50, MultiPass F60,MultiPass F80
Other Color Printers (partially compatable) i560 & i860 (only uses the BCI-3 black tanks,..but BCI-6 for colors)
Posted on Feb 07, 2010
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
All of the sudden the color does not print properly on my canon I850 - its washed out and orangish
Check the color cartridges, especially the yellow. If the yellow looks llike orange or brown then the ink is contaminated. It happens when the printhead goes bad. A membrane between the colors breaks allowing the inks to contaminate each other.
Nov 25, 2009 | Canon i850 InkJet Photo Printer
Used ink tank what and where is it.Popup says tank is full Canon i850
This should do it
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
All the best Pineworks
Oct 31, 2009 | Canon i850 InkJet Photo Printer
Printing, but not full words Canon i850
Sounds more like the actual print head has become dried out and simply needs to be cleaned. This is a common problem with Canon Bubble and Ink Jet printers.
You should be able to remove the cartridge and then the print head shuttle that moves across the page. Once you have it removed, you will need to get a couple of Q-tip swabs and some DENATURED ALCOHOL, NOT RUBBING ALCOHOL as the water in rubbing alcohol will damage the printer head. Wipe the face of the printer head GENTLY with a moistened swab, you should see the dried ink dissolve, do this a few times until you see no further ink on the swabs.
Allow it to dry for a few minutes and then reinstall it into the printer. You will need to run the alignment function of the printer to ensure that the print is aligned properly. That should do it.
Cheers,
Keith
Sep 19, 2009 | Canon i850 InkJet Photo Printer
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
Printer Canon i850 7 red flashes
Inkjet printheads are electrical devices and subject to failure. The error report may be indicating the failure of one or more of the delicate resistive elements in the head. Unfortunately, the electrical drivers failing would probably give the same indication. BTW, alcohol isn't the best choice for cleaning clogged printheads; window cleaner dissolves ink much better.
Jun 15, 2009 | Canon i850 InkJet Photo Printer
I850 canon printer blinks yellow 7 times wont print ,did the waste reset still no good is this a print head failure
You don't want to do a waste reset, ink will overflow everywhere.. but waste ink full is what the 7 blinks means. Resetting the waste ink is like adjusting your gas gauge and not putting gas in, not a good idea...
Jun 05, 2009 | Canon i850 InkJet Photo Printer
Canon i850 not printing
7 times means your waste ink absorber is full, time to let a shop replace the absorbers and reset the counter to clear the error.
Apr 18, 2009 | Canon i850 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
156 people viewed this question
old marine
old marine
