Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 remote issue
My remote starter's red function button on the bottom flashes and beeps when I lock or unlock my car. I've had the remote for 3 weeks and this just started. Any input?
    Sergeant:
  • 306 Answers
Sounds like the remots have lost two way communication. try to disconnect the windsheild antenna.try remotes again after pluging antenna back in.
Posted on Feb 08, 2010
Hi I have a viper 5701 it was working fine for about 2 years and today the car just stop beeping when I lock or unlock the car please help
Was this "beep" from the horn or a siren? The unit could be in valet. Look at the LED on the antenna. Is it on solid? If so the system is in valet. To remove valet, turn ignition on then off, press and release programming button on antenna.
If the LED is not on and, the "beep" came from the siren then, there is an issue with siren itself.
Jan 16, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper remote worked perfect, until now. the unlock/lock and function button work perfectly, except now the car wont start. the start button works and the car tries to start but shuts down. all the...
The issue is not with the remote as you have stated the vehicle attempts to start. The issue may be with an immobilizer bypass module but, I can't say for sure because you mention the year/make/model of the vehicle. Usually the vehicle will give you visual reason for the failed attempt( the lights will flash a set number of times). But, in any event, the issue is not with the remote and more information is required to assist you.
Apr 26, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
I purchased and programmed a new remote to my 5701 starter.security system. the lock and unlock functions work byt i just get a loud beep, flashing red light on the remote and my headlights blink 7 times
The seven flashes from your parking lights is the remote starter error diagnostic. Seven flashes is the message for neutral safety wire. The toggle switch under the dash is in the off position or, if the small, thin black with white wire is not connected to ground.
Feb 08, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hello. My Viper 5701 suddenly doesn't start anymore. I press the button on the 2way, I get a red light by the f instead of the usual green start light. The rest of the functions (unlock, lock, alarms) work...
You should also be receiving an error message. If the parking lights flash six times, it relates to the hood shutdown wire(-) or the brake shutdown wire(+). If the parking lights flash seven times, it relates to the neutral safety shutdown. Check the toggle switch under the dash and flip it to the opposite position.
Jan 23, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My 2 way remote and car are both silent when ever i lock or unlock them and it gives me an error sound when ever i lock or unlock it how do I fix this
Hi, try and see if the user has been switched from car 1 to car 2 press and hold f for 3 seconds or until the remote beeps and the lock and or unlock leds turn on. car 1 will be 1 beep and armed led on. car 2 will be 2 beeps and arm and disarm leds on. if you press the f button while the leds are still lit then you can change to car 1 or car 2. good luck.
Jan 10, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Would like to know what the bottom 2 buttons mean on Viper 7153v
the bottom button is for function shift, and is used (with aux button) to activate certain functions (add on optional features like trunk pop, window roll up/down, rear defroster, etc--all depend on car and install) or by itself for status updates (interior temp check-press once, release, press and hold; remaining runtime-press and release three times, press and hold; lock status-press and release twice, press and hold). it is also used with lock and unlock for silent arm/disarm, and also to enter valet mode.
Feb 18, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Installed. Arm the car locked. About 2-3 hours
You must change the doors trigger connection if you have a negative input change it to positive input or vise versa and try. I’m sure that this is going to end your problems or the smart way is, take it back to Best Buy
Jan 08, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
Dec 21, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
1,164 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
