Question about PfaFF Creative 7570
Pfaff 7510 Power Board Needed!
I have a Pfaff 7510 that needs a "power board" -- any idea where I can get one? A dealer said he has to wait 8 months for one from Pfaff!
5 Suggested Answers
SewTechWayne
  • 186 Answers
SOURCE: Pfaff 1475 CD. Intermittant Power On.
The typical rebuild on this board is done by replacing the 22 micor farrad caps. There are 3 or 5 of them depending if it is new or old style. Note: the power to the sew lamp goes straight from the motor to the lamp, the power to the control panel goes from the motor to the main board (base plate) then to the control panel. If you get the LED's on occasion then it is not the transformer or fuses in the base plate but simply the caps. Sometimes you can just scrape off the electrolytic gel that has oozed out of the caps off of their teminals, but replacing them is the best.
A Pfaff dealer can get a core credit for your board if you take it in. You shouldn't have to pay more than $200-$300 for a rebuilt base plate.
Posted on Jan 31, 2009
  • 632 Answers
SOURCE: i am looking for a parts breakdown on a pfaff 6250
Check this place for a service manual
PFAFF Service Manuals
Posted on Jan 05, 2010
  • 35 Answers
SOURCE: I have a pfaff 7550 that needs a new or repaired
Do you want to learn how to repair sewing machine by yourself? I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Posted on Sep 08, 2010
SOURCE: Need an instruction manual for PFAFF Creative 7510
contact pfaff about a manual first
sewingpartsonline.com
sew4less.com
sewusa.com
ebay
Posted on May 15, 2012
I have a pfaff creative 7510. Which foot is the zipper foot and how do I change the needle position?
First here is a copy of the manual. PFAFF Creative 7510 Instruction Manual
Pg 96 shows a photo of the zipper foot, and directions on how to use it. I hope this helps.
Mar 02, 2017 | PfaFF Sewing Machines
sew4less.com
sewusa.com
ebay
May 14, 2012 | PfaFF Sewing Machines
My 7510 says "adjusting pattern" 248 when I turn
I had this problem a few weeks ago. A new baseplate fixed it. You will need to take it to a Pfaff repair shop
Mar 27, 2011 | PfaFF Creative 7570
I think I need a power board because my machine keeps stopping. Have to wait to start again. Also my light is broke. I have a 1171 and wondered if parts are still available for that machine. It was my moms...
Hi, ..go for the simple first. It could be motor brushes..the next time the machine stops try turning the handwheel and see if it starts to run again. If it does, the motor brushes are worn down. It would probably be less than a 100.00 to repair it.
Good Luck!
May 07, 2010 | PfaFF Tiptronic 2030
Machine just stops but power is on
that is the power board (in base plate) you need a rebuilt base plate. Unless you can rebuild the power board. You can buy a rebuilt board and send your in and receive a core credit. It still will probably run $200 to get one. It will also come with a 2 year warranty.
Mar 16, 2009 | PfaFF Tiptronic 2030
Jan 12, 2009 | Sewing Machines
Pfaff 1222 and pfaff 1229
Have a certified repairman look at the power board in the machine. The power supply circuits are broken on the board itself. Can be repaired with wire and solder. How do I know? Just fixed my wifes 1229 that had the same problem.
P.S. New boards are NOT available from PFAFF or anyone else
Sep 26, 2008 | PfaFF Tiptronic 2030
No display
I have a Pfaff Expression which went the same way, but showed the error message "WD".
My dealer advised me to change the light bulb, which I've done, and since then its been fine.
Hope this works for your too.
All the best.
Aug 31, 2008 | PfaFF Quilt & Craft Pro 7530
Husqvarna Viking #1 blown fuse
You will most likely find that ALL of the "better" manufacturers; Bernina, Husqvarna, Pfaff, will not sell proprietary parts to non-brand dealers. Ultimately, this protects the customer.
With that being said, chances are the problem you are having is NOT a bad circuit board, but a bad power supply. But, since you don't trust your local dealers, find a dealer that is not so local. A two hour car ride is going be a lot cheaper that replacing the wrong part, and NO dealer will return your money on a part that the customer diagnosed as being faulty. I assure you, a Viking dealer somewhere will help you with your problem. You might want to try a Pfaff dealer. They can sometimes obtain Viking parts.
I would try replacing the power supply first. Its a cheaper priced part, and more likely your problem. Its also easier for DIY'ers, but extreme caution must be taken to ground yourself to the machine. Static is always a concern with electronic sewing machines, and even more so this time of year. Proper grounding equipment should be worn while performing any internal repair or adjustment in any electronic machine.
As far as replacing the circuit board yourself, if necessary, also be very careful when disconnecting and reconnecting wires. The connectors are very small and bend easily. Also, care should be taken when tightening screws. Overtightening can cause faults within the circuit board by cracking the solder paths or just plain break the board.
Dec 02, 2007 | Husqvarna Viking 1
Sewing Machines Logo
267 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
