Question about GE GSL25JFPBS Side by Side Refrigerator
No water from dispenser, ice is fine. Tried the hair dryer and light on and solenoid ideas. Still not working. Any idea how to get to switches on door panel, they must be next check or any other ideas? Thanx
    Problem Solver:
  • 15 Answers
I've had the same problem. Take the grill off the lower front of the refrigerator and disconnect the water line at the coupler. Get a small shallow pan or container to catch the water and place the water lines in the container and press the dispenser for water. If water comes from the long line coming from the rear of the unit the filter and water valve are fine. The line going up to the dispenser is most likely frozen. Thawing it is a real chore.
Posted on Feb 11, 2010
Problems with ice maker and water dispenser
Sometimes the water line entering the freezer will freeze up, if it is you can melt it with a hair dryer. If that is not it you will need to test the solenoid valve under the refrigerator for power, if so you can remove the water line on the outlet of the valve or the inlet of the water filter, when you push the water lever water should squirt out of the hose, if not the valve is problem bad.
Mar 17, 2014 | Whirlpool Refrigerators
LG REFRIGERATOR DISPENSER NOT WORKING
x1 sonny ericcson widows mobile 6.1 version i want to change my language to english
Jan 05, 2014 | LG LSC26905TT Side by Side Refrigerator
The water dispenser is not working, I have checked the ice maker which seems to be filling fine and all hoses etc are connected and working, any ideas?
the ice maker has a different solenoid that works it so id say either the switch on the door or the other water solenoid is at fault
Feb 06, 2011 | Samsung 24.8 Cu. Ft. Side-by-Side...
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Maytag MSD 2432GR Water not feeding into Ice Maker
one possible solution is that the ice maker water valve has failed (solenoid). I would try switching the wires on the water valves and see if water goes into the ice maker when you push the water dispenser button, if it does the valve is ok. If you go this far go ahead and fill the ice maker with water ( about half to two thirds full) switch wiring back as first found and see if maker will freeze and dump ice, if it does ok, if not the problem is probably in the ice maker.
Jul 06, 2008 | Maytag MSD2436GR Side by Side Refrigerator
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Dec 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Ice and water dispenser not working but light on constantly
CM, there are 2 things that'd cause this. One is inexpensive, the other is not. First, check the cheap one... That rectangular rubber piece in back of your dispenser area is only a cover for a cantilever device. When you push in on this with a cup, the cantilever swivels back toward you and makes contact with a micro-switch. This switch sends power to the integrated circuit board which, in turn, performs the function you requested (cubed, crushed, water). OK... unplug your fridge. Then use your ears to diagnose this. Push the actuator pad several times in and out and listen for the tell-tale "click click" of the micro-switch. If you hear it clicking, it's good. Plug your fridge back in. Now for the expensive part. If your micro-switch clicks, your dispenser control board is fried and needs to be replaced. (I'm afraid that this is the case because the board controls the light as well as all the other functions.) UNPLUG YOUR FRIDGE BEFORE REPAIRING! To gain access the board, use a small flat blade screwdriver and remove the fascia panel starting at the bottom first. Just begin prying it gently off. Then remove the screws that are holding the board assy in place and gently pull it out. Take note of all of the wiring so you can re-install it correctly. The board number you need is #61005274. Unfortunately, it lists for about $100. A professional repairman would charge you over $200 for the repair, so you're actually saving money here! BTW, we recommend using a Belkin Surge protector for all appliances that utilize electronic controls. (you wouldn't plug you computer directly into a wall outlet, would you?) We regularly use these... http://www.acehardwareoutlet.com/(a1q3xi45sxgfbzm0qejhei55)/ProductDetails.aspx?SKU=3115672
Jul 31, 2007 | Maytag MSD2436GR Side by Side Refrigerator
Water/Ice Dispenser is not working
Some models need the filter inplace to pass water. First check it again with a new filter in just to be sure the filter isn't clogged. Next... do you hear any click or such noise from the rear of the unit when you push the water dispenser? The solenoid valves may be bad. Also check the valves at the back of the frige to see if the filter screen isn't clogged blocking water from getting into the frige all together. Let us know what you find and post again.
Dec 20, 2006 | Amana ASD 2624 Side by Side Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
156 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
