Question about Whirlpool Dishwashers
Sometimes after finishing wash cycle there is water standing in the bottom of the tub.
  • 572 Answers
Check drain hoses for obstruction. check airgap
Posted on Feb 07, 2010
Standing water in base of washing machine
Is it a front load machine? If so, remove the kick plate under the door and there should be a plastic filter that screws in on your right (approx 2"-3" in diameter). You'll need a catch pan that's lower than the bottom edge of the filter cap, as water will flow out of it when removed. I had one that would occasionally eat a sock or other small article of clothing, stopping up the drain filter and causing the tub to hold water. The added weight of the water causes the tub to not turn at the RPMs needed, and sometimes not at all. Let me know if this helps.
Apr 27, 2012 | GE Washing Machines
After wash cycle is finished I lift the tub lid and water is dripping into tub.
You may be looking at residual water dripping down from the rim. If the drip is located near where the water fills from, then you may have a water valve (could be either hot or cold side) that is not able to close completely. The valves are typically replaced, but sometimes cleaning can help for short term. Consult your user manual for removal / replacement instructions.
Aug 18, 2010 | Maytag Washing Machines
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
Won't finish cycle, water still in tub, code nd
check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Standing water at end of cycle
It is normal for a small amount of water to remain after each loadof dishes is cleaned.
Is the water clear or cloudy?
Is there an odor?
How deep is the water? Less the two inches?
Post back with your findings here. OK?
Apr 16, 2009 | Dishwashers
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Standing water in washer after cycle
take off the bottom front panel and clean the coin trap it will be up front just unscrew it have some towels handy
Dec 20, 2008 | Whirlpool GHW9400 Front Load Washer
Kitchenaid dishwasher - water standing at end of cycle
less than 2 cups of water in left after cycle complete
Dec 02, 2007 | Siemens 24 in. SE25A266 ExtraKlasse...
Wont finish washing cycle
suspect not draining. if not then problem could be the filter. at back, remove the small panel at the bottom. you will see a hose from the bottom of the tub to the pump. remove this hose at the tub end and the filter is inside.be carefull, if machine has not drained, a lot of water will come out. disconnect from mains of course
Jun 13, 2007 | Hotpoint Ultima WF860 Front Load Washer
Dishwashers Logo
63 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
