Question about Masterbuilt SBMPG3 Veranda Steel Grill
I have a veranda stainless grill, two of the legs on the disk that cover the flame has rusted and broken off....how do I replace this part?
Same problem, used foil for a while, but eventually I called Masterbuilt customer service and ordered a new flame bowl for $19.99 + shipping, and replaced it.
Posted on Aug 29, 2012
My mom and I both have this grill. Mine is partially rusted (1 leg) and all three of her legs have rusted. We used rocks about 2 in in diameter and 1 inch high to solve her problem. Seems that may have to solve all of our problem.
Posted on Jul 25, 2010
I have the same problem. Have you found a solution?
Posted on Mar 16, 2010
  • rasteele Jul 25, 2010
    I used lava rocks to hold the disk in place, and that worked for while. However, I recently wanted to reposition the rocks and the disk crumbled in my hand. I replaced the grill with a Weber Q series and the Veranda grill is on its way to the dump. Too bad because the idea was great, but the internal parts were made of cheap material.
I have a brinkmann 4 burner. The cross over at the back of the burners has it's own flame. The back of the grill, even at the lowest setting is still very hot. Flames come up between the plates. On...
Sounds like a gas regulator problem. But, somewhat unusual, as most people complain of low flames. In any event, you will need to replace the Hose/Regulator Assembly. They run about $30.00 and can be found at any hardware store or home center, that sell gas grills and accessories.
As a safety measure, after turning off the gas tank, check each burner for blowout or rust through..
I hope this helped you and thanks for choosing FixYa.
Jul 31, 2011 | Brinkmann 810-8530-S Stainless Steel...
I purchased a used Masterbuilt veranda gas grill. The gas regulator fits a small propane tank. Is it possible to replace the regulator so it will fit a large sized propane tank?
Yes, it can be converted to accept a 20 Lb LP grill tan. Contact Masterbuilt Customer Service
1.800.489.1581 to obtain the new hose/regulator assembly.
Hope this helped you and Happy Grilling!
Jul 22, 2011 | Masterbuilt SBMPG3 Veranda Steel Grill
How can i manually ignite the grill
What I do is remove the grates and flame guards and light the burners with a stick lighter then turn em on low and cover them with the flame guards then sit the grates back on there.
May 28, 2011 | Brinkmann Charmglow Stainless Steel LP...
My drop-in 4 burner is corroding and I cannot remove the rust and discoloring. I've had it less than 6 months. No stainless steel cleaner works. A Cal Flame rep (yesterday) told me to try Vinegar and...
What is warranty on unit and does it cover cosmetics? Check that angle out! Can also use that stuff for rust removal on the sides of houses that use well water with sulfur and iron in it. Home depot carries it and works well.
Oct 26, 2010 | Cal Flame 4-Burner Drop-In Grill
Side metal pieces that cover the Viking grill burner are rusted. Do I need to replace the whole burner or just use until burner holes become clogged that then replace?
I would suggest first lifting them out, give them good brush with wirebrush, check if holes are not clogged, check for any not surface damage, they ususally rust bit over on the surface and that is all.
If grill flame is working correctly, and grating have still "decent" thickness and is not falling to pieces, I would still use them normally.
Rust on the grate is usually caused by not using it and exposure to rain/water, as this grating is usually rather solid, surface rust will not affect it. If you have model with stainless graing - there should be no rust on stainless...
That is one of the reasons why you should not wash your grill after use! Fat from cooked food is protecting it from environment.
Hope this will help your worries at bay :-) Enjoy your grill!
Aug 08, 2010 | Viking VGBQ410-3RT Grill
Ducane lp gas grill flame pulsates
Have you replaced the battery ? They do rust and lose contact over time outside.
Apr 14, 2010 | Char-Broil Commercial Stainless Steel...
Flame is very low
take your burner out, an make sure theres no spider webs or nothing blocking the passage way of propane getting to the burner, check for rust, shake it, see if anything comes out, or it mite be time for new burner..
Mar 31, 2010 | Brinkmann 810-8410-S Stainless Steel...
Need a manual for model #sssmpg...stainless veranda steel grill ..bought at a garage sale without the manual...thanks
CLICK HERE for the manual in PDF format.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 14, 2010 | Masterbuilt SBMPG3 Veranda Steel Grill
My 30400040 is rusting to pieces and is only 3
the casing sould have a long warranty but the burners and the cook surfaces do not
you must keep them oiled with veggie oil after cleaning to prevent corrosion
i keep a pump bottle with oil for this reason
Jun 25, 2009 | Ducane 30400040 Stainless Steel Grill
Veranda gas grill - won't light or low flame
One of the major problems with propane gas grills, including the Masterbuilt Veranda, is the pressure regulator. They get to where they do not release enough propane. Some, most, have an adjustment screw that will let you correct these problems. I think I replaced my Veranda regulator with another older pressure regulator from an old grill. Makes you crazy if you don't know this.
Mar 08, 2009 | Masterbuilt SBMPG3 Veranda Steel Grill
Masterbuilt SBMPG3 Veranda Steel Grill Logo
428 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
paulcarew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
