Question about Nikon D50 Digital Camera with 18-55mm Lens
Shutter stays open
I think i've done something to the settings on my D50.....when i press the shoot button....the shutter stays open...it only closes when i press shoot again.....resetting hasn't solved the problem....help
  • kakima May 11, 2010
    What exposure mode(s)? If you're in M or S, check to make sure the shutter speed isn't set to "bulb".
    Problem Solver:
  • 11 Answers
According to what you say, it seems that you selected B (Bulb) as shutter speed (and MANUAL mode).
First, check whether you are on MANUAL mode ("M"); then, check your shutter speed. If it's really in "bulb" mode, all you have to do is dialing the speed button down to figures that match your subject's light conditions and your other preferences involved in the exposure (ISO, lens apperture).
Posted on Feb 08, 2010
Why would my Auto focus mirror not folding up completely.
The mirror is designed to fully swing from top to bottom with out any interference unless something was jammed inside. If you are shooting with the lens off and watching the mirror only partially open something is jammed and needs repair. To test this put the camera in Manual mode ( M on the mode selector dial) Set the shutter speed to 1/4 of a second and press the shutter button. Having a slow shutter will allow you to see if it is fully opening and closing.
If you are making this assumption based on seeing images that have only a portion of the frame exposed, then the most likely scenario is you are taking pictures with the flash on at a shutter speed greater than 1/250 of a second. This causes the flash to fire before the shutter is fully open and therefore only part of the frame is exposed. Google "Shutter Sync Speed".
Good Luck
Feb 27, 2015 | Canon EOS 1100D / Rebel T3 Digital Camera
How do you take a 15 or 30 minute exposure with the Nikon D5000 and how do you set the remote up to snap the picture in this kind of mode?
For really long exposures (longer than 30 seconds) you need to set the camera to the Manual exposure mode and set the shutter speed to bulb. This keeps the shutter open as long as you hold down the shutter release button. Since this is inconvenient, a much easier way is with the remote.
Press the [info] button to bring up the shooting information display. Press the [i] button to put the cursor into the display. Use the cursor keys to move to the release mode (fifth item from the top along the right edge) and press the OK button. The Quick-response remote mode (marked with an icon of the remote control) fires the shutter when you press the button on the remote. the Delayed remote mode (marked with the remote and "2s") gives you two seconds to hide the remote behind your back when taking self-portraits.
In either of the remote modes, when the shutter speed is set to bulb the shutter opens when you press the button on the remote and stays open until you press the button again (or the camera battery dies). This way you can press the button, go and do something else for a while, then come back and press the button again.
Information on the release modes is in the "Release Mode" section of the manual (page 65 in my copy). Information on using the remote control is in the "Self-Timer and Remote Modes" section of the manual (page 67 in my copy).
Mar 16, 2011 | Nikon ML-L3 Remote Control
I get "Err" on the
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Jan 25, 2011 | Nikon D50 Digital Camera
How do i set up my nikon d500 to use my nikon ml-l3 remote controller
I assume you mean either the D50 or the D5000.
In either case, set the camera's shooting mode to one of the two remote modes. Quick-response remote mode fires the shutter when you press the button on the remote. Delayed remote mode waits two seconds for you to hide your hand behind your back before firing the shutter.
Oct 10, 2010 | Nikon ML-L3 Remote Control
Hi i have dropped my d50 and err comes up
There is a motor/gear assembly inside the camera that moves the lens in and out and covers the lens when it is retracted. When it dropped, you most likely cracked or shifted something out of place. A broken tooth does not stop function, but shudders when it hits the gap. A shifted gear, slips and similarly may cause this effect. If it doesn't open the shudder, you get no picture.
You will need to open it up and attempt to repair the mechanics that drive the lens.
May 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Shutter opens, but doesn't close? I advance my film, press the shutter release, and it opens, but stays open. The only way my shutter will close is if I press the battery check button. I read a trouble...
That camera needs tobe services. The IC2 is the technicians code that tells where to start. With the problems you describe it would be best ot let a technician overhaul and recalibrate it if possible. then you will have a camera that operates like new.
Apr 28, 2010 | Canon EOS-AE-1 35mm SLR Camera
Nikon D50 While shooting pictures the shutter button stopped work
TURN ON CAMERA. SEE IF THERE IS A MESSAGE. NOW, TURN OFF CAMERA. TAKE OFF LENS. REPLACE LENS- MAKE SURE YOU HEAR A "CLICK" TURN ON CAMERA AND TRY AGAIN. OK?
Mar 03, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
My Nikon D50 locks up intermittently
you like to try and swapping batteries.. i guess it couldnt supply enought power to the shutter motor.
Aug 13, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Feb 03, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera with 18-55mm Lens Logo
166 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
