Question about Refrigerators
Model GT22DMXGW00 leaks water from under it that amounts for up to couple of gallons in few hours then stops for several hours, it doesn't have icemaker connected.
  • 572 Answers
Ur drain is clogged
Posted on Feb 07, 2010
What could a fairly loud thunking noise coming from my engine be when turning off my 1984 chevy van 20?
First let me say it is NEVER good to drive a car overheating , you can ruin very expensive parts.It hurts your engine and your wallet. If permanent damage has not all ready been done , have it towed to your trusted shop, it sounds like your water pump has failed
Apr 03, 2012 | 1985 Chevrolet Sportvan G20
Just bought a side-by-side wirlpool refrigerator and it leaks water for a few seconds after you pull the cup away. Eventaully it does stop leaking, but why doesn't it stop right away. I just bought it...
Hello, Thank You for using FixYa. I will be helping you today.Try running about a gallon or two of water out of it to get the air out. It can also be not enough water pressure to the unit from your house that causes the same issue.
Thank You and please rate my answer if it was helpful..
Jun 20, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I have a Rheem 40 gal. tank that is leaking water front the top where the vent stack is. It is pouring out. Can it be repaired?
A leaking water heater cannot be repaired, assuming it's the tank leaking and not nearby water pipe.
http://waterheatertimer.org/Water-heater-leaking.html
First thing is to protect your property from catastrophic tank failure where tank ruptures and water runs until it is shut off:
Tanks are under pressure when they are hot.
Close cold water shut-off located above tank.
Turn control knob to 'pilot' so pilot is lit but burner will not turn on.
Open hot side on tub for few moments to relieve tank pressure.
Now your property is safe.
You need a new water heater.
In mean time, gas water heater makes 41 gallons hot water per hour.
Shower used 5-9 gallons hot water.
Bath uses 10-15 gallons hot water.
You can turn on water heater for short stretches and limp by until you get a new heater.
Steps for installing gas water heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Dec 20, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Just installed aqua/cleer reverse osmosis system and the water doesn't seem to be going into the holding tank, however there is water that is coming out from the tap.
Make sure all the lines are hooked up correctly. It is going to take 3-8 hours to fill a 3 gallon RO storage tank. It depends on the capacity of the membrane (IE: 14, 20, 30, 50 or 75 gpd). It also depends on the TDS of the water. Water that has high TDS 500+ppm will take longer to produce product water than TDS of 100ppm. Check the pressure in the RO tank. When empty (In a 3 gallon tank) there should be 7psi pressure. A ten gallon tank takes 10psi. If it needs air you can use a bicycle pump to add appropriate air. Make sure the tank valve is turned off when adding air.
Do not use the RO faucet for several hours to allow tank to fill up. Also you should dump the first couple tanks of RO water to make sure any carbon fines are rinsed out.
RJ
Nov 07, 2010 | Culligan Under Sink Water Filter
Energy smart hot water heater not giving ample amount of hot water both elements ohm at 12.5
For images and product information
For manual
You checked ohms, did you check for 240V across lower element when lower element is turned on?
Energy smart electric water heater
has a control box on top of unit. Water heater does not have typical thermostats that can be tested and replaced. Temperature sensors located above each element send information to control box through small black and red wires. Temperature sensor sells for about $40, but there is no test listed that shows how to determine when sensors fail.
Potential problems:
-Temperature sensor is not reading correct temp
-Control box not processing correct temperature information
-Selector on control box set to 2, 3 or 4
-Thermostat temp on control box set lower than 120 degrees F
-Sediment build-up starting to surround lower element so water doesn't circulate (see if drain valve runs full-open
Oct 08, 2010 | Water Heaters
I changed the lower raditor hose. Standard remove and replace. No problem. Replaced water and 1 gallon of anti-freeze. Let system warm up and turned on heater. No problems. Test drove and no leaks. Next...
the sweet sickly smell is normal for new anti freeze.once you have run the car for a couple of miles the smell will dissipate.the white foamlike stuff is chalk/lime in the water,harmless.
Aug 21, 2010 | 1996 Jeep Cherokee Sport
96 nissan altima with ne water pump and thermostat
1. Improper water circulation: Sometimes, eventhough you are sure that you have enough water on your radiator, your car still overheats. It might probably be that the water is cannot circulate properly, which results to improper cooling process. There are several reasons for this which you can discover by yourself. To verify if the water circulates properly, start your engine without the radiator cap. If water circulation is good, you should notice that the water pops smoothly over the top but still retains the amount. Another way to check, detach one of the ends of your radiator hose from your radiator and see if water flows continously over.
If water doesn’t circulates well, check the thermostat if it’s open. It should be open, meaning clean, and the water can pass through it.
If thermostat is clean and still the water doesn’t circulate properly, then you have to check the water pump. That’s probably where the problem is. A little leak on the pump will cause improper flow of water through the radiator system.
If you are sure that the problem is not about water circulation, another thing you can consider is check the engine oil. Very low amount of oil can cause greater friction of the mechanical system of your engine. If it’s not time to change oil yet, you can add over some amount of oil until advisable amount is reached.
While we can’t be always sure about our engine, especially if it’s not new, we should be prepared when it happens. Bringing extra gallon of water in your trunk will surely help.
Jul 28, 2010 | 1996 Nissan Altima
Water leaking in basement because there is a small leak in current expansion tank. can we stop water from leaking tonight and still have water to house? and are these tanks easy to replace?
For tonight I would set a bucket under it to cathc the water from the leak. The tank will not start to leak much worse in the next few hours...
And, no it is not hard to change the tank. Just messy....:-) Becareful though as the tank may be heavy if the bladder has ruptured...
Simply use two wrenches and unscrew the tank and then tape or dope the threads and screw the new tank back on...just that simple...make sure you get a fresh water exspansion tank and not a heating one...
heatman101
Mar 30, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
How many gallons per hour does this car lose?
hey
at the begging u should clarify how many gallon u used.
112 miles at 28 miles per gallon --> 4 gallons burned (112/28)
So that means we leaked 11 - 4 = 7 gallons
Now figure out how long the car was driving.
112 miles at 64 miles per hour --> 1.75 hours
So, leak was at a rate of 7 gallons in 1.75 hours
7/1.75 = 4 gallons per hour leaked.
Jul 10, 2008 | 2008 Chevrolet Corvette
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
