Question about Roper REX4634KQ Electric Dryer
Forgot how the idler pulley goes - Roper REX4634KQ Electric Dryer
    Sergeant:
    Champion:
  • 263 Answers
My whirlpool dryer makes a horribly loud racket. Is the idler pulley or the tension pulley
There is only 1 pulley in most driers, so the idler and the tension pulley are the same part. The idler pulley is on the tension arm, located beneath the drum. A squealing sound is usually associated with the pulley. If it is a slapping or thumping sound it may be the belt, which goes around the drum and the motor shaft. The part numbers are on the parts, or you can order by model. The idler is less than $10.
Apr 03, 2016 | Whirlpool Dryers
Remove the idler pulley on a 1998 cadillic sts
loosen the big nut in the centre of the idler pulley . Behind the pulley there will be a long adjusting bolt adjust until the pulley is completely free. finish undoing the big nut and the pulley and spacer will slide off the shaft. Remember which way the spacer goes
Dec 28, 2013 | 2000 Dodge Neon
Trying to put belt on drier but its to loose what im doing wrong
make sure the belt is around the motor pulley and the idler tension arm.it goes on like a serpintine belt on a car.pull the pulley to one side and then put the belt on the motor pulley and then release the idler pulley it should tighten up your belt.the outside of the belt should run along the inside of the idler pulley.it will almost look like a figure S.
Nov 13, 2010 | Crosley CDE6000 Electric Dryer
Changing the belt
goes around idler pulley and motor. idler pulley fits into slots on bottom of dryer and the belt tension holds it in place. looking at it from the front and going clockwise the belt goes around the drum and then around the motor pulley and thru the idler pulley. in fact if you put the bottom loop of the belt thru the pulley from the left you then loop it around the motor pulley.
Jun 26, 2010 | Estate TEDX640JQ Electric Dryer
I have a John Deere 214 that threw the secondary drive belt. I am replacing the belt with a new one. The problem is, even though I have refered to the shop manual and the owner's manual, nothing shows a...
the belt goes on the rear end and the front on the double pulley and pull down the idler pulley and the bottom part of the belt goes over the top of the idler pulley, i do hope that i helped you,thank you.
Dec 26, 2009 | Garden
Took serpentine belt off and forgot how its goes back on. 1997 ford f150 4x4 5.4
here it is
b5421bb.gif Item Part Number Description 1 6B209 Drive Belt Tensioner 2 8678 Belt Idler Pulley 3 10344 Generator Pulley 4 8509 Water Pump Pulley 5 8678 Belt Idler Pulley 6 3A733 Power Steering Pump Pulley 7 6316 Crankshaft Vibration Damper and Pulley 8 — Drive Belt Tensioner Pulley 9 2E884 A/C Clutch Pulley (If Equipped)
Apr 12, 2009 | 1997 Ford F150 Regular Cab
How to install drive belts to 1996 nissan quest
go here for help
http://autos.groups.yahoo.com/group/villagerquest/files/
Item Part Number Description 1 — A/C Compressor Drive Belt Idler Pulley Adjustment Bolt (If equipped)
(Part of 8678) 2 — A/C Compressor Drive Belt Idler Pulley Tensioner Bolt (If equipped)
(Part of 8678) 3 8678 A/C Compressor Drive Belt Idler Pulley (If equipped) 4 8620 A/C Compressor Drive Belt (If equipped) 5 2E884 A/C Clutch Pulley (If equipped) 6 10346 Generator 7 10344 Generator Pulley 8 11719 Generator Adjustment Bolt 9 — Generator Locking Bolt 10 8620 Generator Drive Belt 11 6312 Crankshaft Pulley 12 — Water Pump and Power Steering Pump Drive Belt Adjustment Bolt (Part of 8678) 13 8678 Water Pump and Power Steering Pump Drive Belt Idler Pulley 14 — Water Pump and Power Steering Pump Drive Belt Idler Pulley Locknut (Part of 8678) 15 3A733 Power Steering Pump Pulley 16 8620 Water Pump and Power Steering Pump Drive Belt 17 8509 Water Pump Pulley A — Tighten to 16-20 Nm (12-15 Lb-Ft) B — Tighten to 33-37 Nm (24-28 Lb-Ft)
Mar 28, 2009 | 1996 Nissan Quest
Need a btlt route so i can put the new drum back in my ge profile
route the belt around the drum, pull the spring loaded idler pulley to the postion that requires you to hold it there..
put the belt : 1 through the motor pulley and around the idler pulley, or 2. around the idler pulley which ever works to keep the tensioner tight. (Idler pulley, tensioner same thing its the pulley not on the motor.
Once you put the belt on the durm, pull the idler pull so there is tension on it it should be clear how it goes.
Doc
Feb 08, 2009 | GE Profile Harmony DPGT750EC Electric...
Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Nov 13, 2007 | Kenmore 60172 Electric Commercial Dryer
Roper REX4634KQ Electric Dryer Logo
83 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
