Question about Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D
B&S 3.5hp rotorvator. No Spark
Hi . I have a B&S 3.5 hp rotorvator. I cant get a spark? I have changed the coil,condenser and points and still cant get a spark any ideas? I have set the gaps and the coil to 20 thou and the points the same. Not even getting a weak spark
  • 677 Answers
I would first change it over to electronic ignition, you can purchase a kit online.
You did not tell me you changed the spark plug, have you ? Please let me know.
www.smallenginewarehouse.com
Posted on Feb 07, 2010
My 1991 chevy s10 2.5l want crank it's getting red spark
Hi Austin:
Counting on my fingers I make that over 25 years old, so the maintenance history and mileage become very relevant.
I'd be considering an ignition tune-up as an appropriate first step.
Changing spark plugs, plug lead harness (wires), rotor, cap, coil, Points & condenser (or solid state components.
Chances are it will show a remarkable improvement.
Jul 15, 2016 | Cars & Trucks
I have a 16.5 hp onan engine in a 1979 gravely tractor -with engine running why are my ignition points sparking
Ignition points open to collapse magnetic field in ignition coil to make spark. They have a condenser across the points to reduce the spark which comes because the current collapse also generates a back feed current in the now open circut in the primary windings. This is the spark that damages and wears out the points. Check with a competent Auto Electrician that the condenser (also called a Capacitator) is the right capacity for the coil being used.
Jul 20, 2014 | Garden
Toro snowthrower coil condensor points
If you have changed sparkplug and coil and cleaned flywheel, you probably have a kill wire problem. Disconnect kill wire from coil and try again.
Apr 04, 2014 | Tecumseh Enduro Horizontal Engine 5 HP...
1969 vw beetlewont start no spark from coil
It has a set of points and condenser in the distributor that grounds the coil.
Have you checked the points to see if they are burnt or out of adjustment ? Is the distributor turning when you crank the engine ?
Aug 18, 2012 | Volkswagen KarmannGhia Cars & Trucks
Case 580CK gas...intermitent spark at points, new coil. Condenser needed?
Hi, the condenser connects to the negative coil terminal and is used to absorb the point spark so the points will not wear out prematurely. If you are getting sparks in the points, I recommend you replace the condenser.
Dec 14, 2011 | Cars & Trucks
Model H80-155003 engine magneto has no spark. Replaced coil, condenser & points. still no spark. Set points at top dead center of cam to .020. I need to check wiring, I have digital multimeter. I...
Check the ignition cutout which should short the coil to ground to stop engine, isn't operating while you are cranking engine.
To check grounding, measure resistance from chassis to non chassis side of points.
This should be very low (= resistance of coil primary) and reduce further when points close.
Feb 21, 2011 | Briggs & Stratton Ignition Kit 2-8 HP...
No spark checked points they have spark how do I check coil assy. or change wire to spark plug a OEM ignition coil is spendy
If the points are working correctly you are having a problem with the condenser ,coils,spark plugs,or spark plug caps. Honda condensers are notorious for being week. Spark plug caps have resisters that burn out or corrode. Coils can go bad but do not usually go out in pairs. Plug wires can short out the spark if the are old and cracked or wet. One coil does two plugs so on shorting wire on each coil will kill all the spark.You can see this if the bike is running at night where it is dark. Aftermarket Accel coils($150-$200) might be a good option along with an after market CDI ignition (may still be available through Parts Unlimited about $200). I suspect that your problem is still the points. Power is going to them but not leaving them. Even new points may have to be reinstalled several times before they decide not to short to ground.
Aug 25, 2010 | 1972 Honda CB 350 F0
No spark
did you make sure the gap was set right on coil & flywheel it should be .020 between magnet on flywheel & the coil & the same thing with the points in the open possition between points & condensor
Jun 07, 2009 | Garden
Cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Mar 21, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Week spark on honda 5.5hp gx160
Hi
I suppose is 4 stroke engine.Before adjusting the breaker points gap at .020 check if the breaker points are burned.Also check the condenser(change it).Change the spark plug with a new one with the same heat range.The plug gap is .030.
best regards savumihai71
Feb 12, 2009 | Electrical Supplies
Briggs & Stratton Ignition Kit 2-8 HP Engines with Breaker Point Ignition #5012D Logo
1,217 people viewed this question
Top Briggs & Stratton Hammering Experts
Dan Webster
Dan Webster
John Trevino
JOHN LAPIER
Are you a Briggs & Stratton Hammering Expert? Answer questions, earn points and help others
