Question about HP LaserJet 5550 Printer
My printer was printing just fine and now it is printing out blank pages. I just put in a new ink cartridge before printing and now it won't print at all. The little tear drop shape on the printer is flashing red. What happened to the printer??
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
Prints out blank pages, won't test print, new ink, cleaned multi-times, still blank!
Silly question from my side: have you removed the tape covering the nozzles of the cartridges? Is it original Brother cartridges, or is it compatibles?
Aug 23, 2011 | Brother MFC 490cw Color Inkjet...
My HP deskjet 2050 all-in-one printer only shoots out blank paper and won't print. It used to say there was no paper in it, which there was. It scans & prints just fine - just won't print...
Any error messages on the printer digital screen or the desktop? I take it the "The ink is fine" means that there is ink in the cartridges!
Try a test print via the Control Panel> Printers and Faxes> properties > Print test page.
May 31, 2011 | HP PSC 2210 All-In-One InkJet Printer
Dell 720 printer , new ink cartriges but prints blank pages
I know it sounds silly, but never underestimate the obvious.
Did you remove the plastic protectors from the cartridges?
Another solution maybe to return the cartridges to the store for an exchange. It has only happened once to me, but I exchanged the cartridge for another "new" one and it worked fine.
Good luck
-Carlos:
Jan 07, 2010 | Dell Inkjet 720 Printer
Printing gives only blank pages...
Maybe you need performance a preventive maintenance if you know how great, if not you can call a Printer tech in your area.
May 27, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Please help me, my epson inkjet all in one printing just blank blank blank
Epson printers will not accept continuous ink cartridges. That is why you are getting blank pages. I recommend just buying the ink cartridge as you need them.
Good Luck
Jan 05, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Lexmark z640 has stopped printing - goes through the motions but no ink on page
Some third party cartridges will not work with your printer as they are remanufactured from used cartridges.
It is more expensive to buy genuine Lexmark ink, but atleast you know it will work.
You may try reinstalling the driver before buying new ink.
I hope this helps.
Good Luck.
Oct 18, 2008 | Lexmark Z640 InkJet Printer
Printer HELL !! need assistance
illustrate on how to replace the ink cartridge on printer
Sep 15, 2007 | Office Equipment & Supplies
PRINTING BLANK SHEETS
You need to put the test page that was printed into the scanner part of the printer and then press the scan/blue button. This is so the printer can calibrate the new ink. When you have done that the next time you turn on the printer a blank page will not be printed. When you next change ink you will have to repeat the above procedure.
Sep 01, 2007 | HP PSC 1315 All-In-One InkJet Printer
HP LaserJet 5550 Printer Logo
173 people viewed this question
Seeker5211
Seeker5211
