Question about Maytag 22 Cycles Topload washer, SAV365Z
Washer wont work
Filled washing machine with clothes and turned on the washer to fill up with water. as i turned around to put something else in the washer, the lid slammed down and now the washer wont work.
  • 572 Answers
U dammaged the door switch
Posted on Feb 07, 2010
I want to use Woolite with my Maytag Centenial, how can I fill with washer with water without adding clothes?
Just put in wash cycle and wait for the water entering to stop them pop the lid. Naturally you did not have any clothes in there while the water was filling up the tub.
Aug 26, 2017 | Maytag Washing Machines
My LG washer/dyer fills up with water after its done running, it washes and drys then fills up
something is holding the input valve open small pieces of rust etc. will do this .that is why they put screens in the ends of the hoses
Sep 23, 2017 | Washing Machines
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Awhile back I had FixYa help me with my washer. It would fill up with water and then just stop. It turned out to be the lid switch. Now about a month or so later I went to wash a load of clothes and again...
Hi.
If the lid switch is OK and there is water getting into the machine, then test and replace the pressure switch that detects water level.
Here the part:SUB 12002304 (Water Level Switch Kit)
Part is nr 6 in this diagram.
Also test the inlet valve to ensure that dual inlet is working. If hot is not filling, the machine will not complete filling.
A technician can swap valve contacts to find out if
both valves are opening.
If there is no filling at all, check the inlet valve and inlet duct:Water Inlet Valve.
Inlet valve is at the back of the appliance. It can be tested reading Ohms at terminals.
Aug 11, 2010 | Maytag LSE7806A Top Load Stacked...
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Washer won't drain or spin
top loader ??? or front loader??? if top loader you have broken your lid switch, will fill, agitate, but when it comes to drain/spin for safety reasons if the unit doent recognize the lid closed it will not advance...if yo have a front loader then i would suspect that something has gotten into the pump assy and preventing drainiing of water therefore will not spin
Mar 02, 2009 | Kenmore Washing Machines
Washer fills with water but wont continue washing cycle
Your lid switch is bad or loose.. open and close your lid and see if you can hear clicking noises.. if not.. then your lid switch is broken.. good luck
Jan 21, 2009 | Washing Machines
GE top load washer does not agitate or spin.
sounds like a bad lid switch how old is it?
Dec 29, 2008 | Washing Machines
MY WASHER FILLED UP WITH WATER, BUT THEN IT JUST QUIT WORKING.
I believe it is your lid switch. I have replaced 3 this week. If you get me the model number i can tell you for sure. Another thing that caused this is the motor to go bad. Do you smell a burning smell when it is trying to run after the fill up? If not get me the model number and i will get you the part number for the lid switch.
Nov 21, 2008 | Maytag PAV2300 Top Load Washer
LG Washer WM0642HW: Not enough water
Turn clockwise the water level sensor set screw a half turn "clockwise" under the top of the machine lid.This is the only way to rid yourself of the WICK WATER RUB WASH METHOD that is just terrible. Especially with a full load ! BELIEVE ME. I really wonder if consumers who have the WM0642HW earlier produced version with the nozzle spray system in the top of the door seal are having these troubles?. Mine is a 2009 verson of the WM0642HW, No Forced Water Recirculation. ( Discontinued) and how it was preset for fill at the factory made it perform terribly. Only after i adjusted the water level sensor does it perform well the first time around. Have yet had to rewash anything since the adjustment i made for the fill level. Good Luck.
Nov 09, 2008 | Washing Machines
Maytag 22 Cycles Topload washer, SAV365Z Logo
156 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
