Question about HP PSC 950 All-In-One InkJet Printer
Hi, The digital readout reads, remove and check your black ink cartridge, i have tried this but the readout persists, it will do no work. Please can you help?
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 07, 2010
Out of toner
Make sure that the toner ink cartridge is a genuine Lexmark toner cartridge. Try removing the toner cartridge and then shake the toner sideways. Re-seat the toner cartridges and check if the error persists. If it does, please contact our Technical Support Hotline.
Dec 03, 2012 | Lexmark T520/522 BLACK PREBATE TONER
Replaced new ink keeps saying right cartrige is incorrect wont let me print. the cartrige is correct i paid $50.00 for a two pack of black and color ink!!!
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One InkJet Printer
Printer (HP deskjet F4180) showing E and color
This means that there is issue with the Ink Cartridges.
Please remove and re-insert the cartridges.
Check the expiration date on them. Also make sure that you are using genuine HP Cartridges, not refilled or Remanufactured.
If the issue still persists, please replace the ink cartridges.
Jun 02, 2010 | HP Photosmart 2575 All-In-One Printer,...
I just put in a brand new black ink cartridge, but the black ink will not print. It acts like it is, but nothing comes out.??? The color ink works fine.
Please follow the instructions given below ton print a test page and check if black color prints. If not then clean and reseat the black cartridge. If issue persists then contact HP Support to replace problem cartridge if it is in warranty and not a refilled cartridge.
  1. Press and hold the Power button, and then open and close the top cover four times.
  2. Release the Power button.
Oct 12, 2009 | HP DeskJet 3650 InkJet Printer
I replaced a new black ink catridge, the black is
For that problem kindly try doing the ff:
  • Re-seat the inks both color and black then try printing
  • Re-seat the Printhead of the printer then print again
  • Try changing the print quality to best then try printing
  • if problem still persist call 1800 421 6699 and the technical rep will replace the printhead
Hope this will help
Thanks
Byron
Sep 23, 2009 | Kodak ESP 5 Printer
Dx4450.New ink put in but won't print
Hi Mel
unplug the printer--> remove all the cartridges from the printer--> wait few minutes--> plug the printer--> install the cartridges
I hope this helps. If so, please take a moment to accept and rate my solution accordingly
Nov 15, 2008 | Computers & Internet
Printer will not print black ink
Hi please try these steps:::
Right-click the printer icon, and then select 'Properties'.
2. Click the 'Maintenance' tab, and then click 'Deep Cleaning'.
3. Select 'All Colors', 'Black' or 'Color' for the print head to be cleaned.
4. Read the message displayed, and then click 'OK'. The power lamp blinks and print head deep cleaning starts. (Do not perform any other operations until print head deep cleaning is complete. Print head deep cleaning takes about 1 minute.)
IF ABOVE STEPS DOESN'T WORK TRY THESE STEPS BELOW
Check ink tank vent hole The ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is as shown in Figure (1), it is properly removed.
    *BCI-3's shown in this example.
  3. If the orange tape is as shown in Figure (2), remove the remaining tape to the level shown in Figure (1).
  4. Make sure each ink tank is snapped into the printer.
    IF THESE STEPS DIDNOT WORK THEN YOUR PRINTER NEEDS REPAIR(You might need to change the printer head.)
Jun 09, 2008 | Canon i850 InkJet Photo Printer
Error check ink cartridge
Hi ,
As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
Steps >
Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
keep on holding the keys down until the machine turns off automatically .
after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
Thanks
MAC.
May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Kodak Easy Share 5300 Printer
Please consider checking the new ink cartridge expiry date and the replacement is same model with the old one. Now, when replacing the old one please follow the proper procedure like some models uses software application in doing so. Try cleaning the nozzle procedures for unclogged ink-paths. If still persist you may need to replace the printer head. Otherwise, check the contact also between the ink and tray contactors. Hope this will solve the problem.
Best regards,
Rosener
Jan 30, 2008 | Office Equipment & Supplies
Dell 922 All In One Printer wont print
did you remove the seal of new catridge. bye
Sep 24, 2007 | Dell 922 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
