Question about ViewSonic VX900 19" LCD Monitor
It appears to come on...then it goes black. If you turn the power off and then on..it flashes with a display then goes black. Any ideas
  • 11,361 Answers
The problem can be in the inverter board, look for open fuse, or worst will be bad lamp/lamps. You need to open it up and report back what you see so we can guide you furhter: see what bad lamps look like: http://s807.photobucket.com/home/budm/allalbums
Posted on Feb 08, 2010
I have a tec SL39N digital scale. When I plug it in the mumbers appear across .. 111111. 222222. 333333 etc. It goes to 9999 and then goes back to 88888and the 8's keep flashing. Help! Thank you.
Good Evening Paul, and Happy Holidays.
You can view the manual for your scale here:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwil1tu6oeTJAhUG_mMKHRbRBMkQFggdMAA&url=http%3A%2F%2Fpdfstream.manualsonline.com%2F4%2F4249c7d6-8aca-4d71-82c7-2a6ad53f509b.pdf&usg=AFQjCNHFxSA5IvPtpNw0tHJgBjUjLNtxQg&sig2=yTmgL-Oxe95lCTHu4KY_Lg&cad=rja
It makes mention in several places about the scale displaying flashing 1111111 and flashing 8888888 displays, which fortunately appear to be signs of it turning on and saying 'ready'. Some of the display action appears to be affected by how long the gap is between when the scale is plugged in and when the power switch is turned on.
Hoping this helps!
D
Dec 18, 2015 | Health & Beauty
POS X Evo TP1 A1N screen appears to be off, but power is on
first of all check your monitor. it would be the best if you can plug some other monitor just to check... if your monitor is OK then probably you VGA is bad and you`ll have to change it.
Dec 14, 2013 | POS X POS-X EVO TouchPC (PXI-EVO-TP1-A1N)...
Sony KDF-E50A10 Power Up Problem with Display
yes it possibly lamp ballast board is faulty
Oct 13, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
The display flashes on for a second or two, then goes black. This happens each time it gets a new type of signal. So for example when booting up the PC it displays the video card logo for a second, then...
Bad caps can look normal but can have high ESR, you also need to check the DC voltages. You can also have bad lamp assemblies, etc.
Make and model will help also, you can look for service manual here: www.elektrotanya.com
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Nov 29, 2010 | Samsung Computers & Internet
Monitor will flash the display for a second then go black again.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Apr 12, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Screen goes black then flashes grey to black.
you are right: resolder the power connector
Nov 06, 2009 | Dell Dimension 8300 PC Desktop
I have a VP201m. display flashes at startup and goes black
That's not monitor problem, it's your CPU, probably the Operating System crash!!!( Windows,etc).
Try reinstall it to solve the problem...
Oct 18, 2009 | Computers & Internet
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
At power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Mar 01, 2009 | Televison & Video
Sony KDL-32ML130 lcd tv
Not really that tough. Sounds as though the backlight is shutting down, either from a power supply failure, or a failure of the backlight circuit itself. You can verify this by holding a flashlight to the screen in the area where the menu usually appears to see if it displayed on the LCD panel with no backlight. If you can faintly see the menu displayed, your backlight has shut down and the most likely cause is the backlight inverter board, followed by the power supply and the backlights themselves which are part of the LCD panel. If you found this information answered your questions, please be sure to rate it. Thanks!
Oct 24, 2008 | Televison & Video
ViewSonic VX900 19" LCD Monitor Logo
312 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
