Question about Kenmore Kitchen Ranges
Every time we turn the oven on it shuts down the oven and the fridge
  • 572 Answers
U have an electical problem. get an electrician
Posted on Feb 07, 2010
Stops after 4 mins
Can you hear the "whirl" of the fan? It is possible the fan is not turning & cooling the oven therefore it will shut down when it reaches a certain temperature. This could be caused by a supply fault to the fan or the fan motor, either way it would need to be tested by a qulified engineer.
Nov 10, 2013 | GE JVM1653 Microwave Oven
I turned on self-clean on my Whirlpool self-cleaning oven. After a certain amount of time the oven completely shut down with the control panel blank and the oven door is unable to open. I have turned off...
There is a couple of things that could cause this. This oven has a cooling fan that is supposed to keep the electronics from overheating. There is a thermo cut-off that is supposed to shut it down if this happens.
If it worked like it should, all you have to do is replace the thermo cut-off and possibly the fan. If it didn't the control board will also have to be replaced.
Jan 07, 2012 | Whirlpool RBD305PD Electric Double Oven
Oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Jun 28, 2009 | Ovens
Confused about pilot lights?
electric ovens do not have a pilot light.
there should be a thermostat for the water heater somewhere - turn it to the coldest position
Nov 13, 2008 | Lang Manufacturing EHS-APM Electric Oven
Fridge side not working but freezer side is
The evaporator is freezing over because the defrost mechanism is not working. Check the defrost timer and the defrost heating element. Go to attached site for parts. Search Over 2 1 Million Appliance Parts Search Over 2 1 Million Appliance Parts
Aug 26, 2017 | Frigidaire Refrigerators
Oven shuts off by itself
When your oven reaches the desired temp. it shuts down then turns back on again after it cools down a couple of degrees and cycles like this during the complete baking cycle. If your ignitor or oven valve is getting weak it would cause this symptom.
Oct 31, 2007 | GE JGRP20 Gas Single Oven
Amount of time the compressor and fan stay on
its the old story, is it now working fine, if so leave it,
the answer to your question though, how long would it take to cook a pie with the oven door not closing properly, or at the wrong setting,
it varies by what the outside influences are, as long as it settles down in the end and now works properly then all is well, don't forget the fridge will have warmed up as it were so it would take a while to get it to the right coldness, if the door wasn't closed it would take forever wouldn't it????
Oct 14, 2007 | Refrigerators
Microwave oven turns off
It could be an overheating magnetron. There is a thermostat inside (mounted to the side of the magnetron) which senses excessive heat and opens up, disconnecting the power to the oven. If that's the case, unplugging it and plugging it back in will not fix it. It will come back on by itself after it cools down. That's another indication that it might be a thermostat kicking out. You might try to further characterize the failure: - happens only when cooking on full power? - also happens when cooking on a low power level? - shuts down every time you use it? - only shuts down after XX amount of time cooking? Once you characterize it more, I can make further suggestions. It may also be a bad connection on the control panel.
Nov 03, 2006 | Hotpoint RVM1435 Microwave Oven
Kitchen Ranges Logo
48 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
