Bi-amp I have an Adcom 5802 that has bi-amp posts on the back. Do these posts have a crossover for highs and mids or what exactly do they do?
    Scholar:
  • 54 Answers
After examining a picture of a 5802 ( I have been servicing adcom for over 20 years ), these are not bi amp posts, but bi wire posts.
Bi-amp means that 2 amps are being used, one for highs, one for lows. This means that you have no crossovers in the speakers, instead, you have an electronic crossover between the amps and the pre-amp. The highs and lows are separated in the electronic crossover. One amp handles the lows, one handles the highs.
Bi-wire means that you have the crossovers still inside the speakers. The amp handles the full range of music ( highs-mids-lows ). Different kinds of speaker wire produce different results. If you have bi-Wire terminals on your speaker, they come with shorting wires, that tie the tweeter + to the woofer + on the back of the speaker, and the tweeter - to the woofer - . When the shorting wires are removed completely, you have now electrically separated the tweeter and woofer from each other, while maintinaing the crossovers ( inside the speaker ) for each.When this is done, you can now bi-wire the speakers and amp, and use different kinds of wire for the lower frequencies and the upper frequencies, depending on your ears ( everyone hears a little differently, thats why there are so may makers of components, and wire ).
Why do we have crossovers?.....the tweeter voice coils ( the things that make the sound ) are made of hair thin wire. This wire cannot handle much power and if you were to put bass in to a tweeter, you would burn the tweeter out almost instantly. A tweeter is a very light, fast moving device which can react very quickly to high frequency sounds ( symbols, triangles, guitar strings....). Woofers are more rugged. They have voice coils made of heavier wire and are designed for larger movements that Bass demands. Subsequently, woofers aren't very good for high frequencies because they are slower devices.
So what do we do ?.....Keep the lows away from the tweter and the highs away from the woofer.....thats the job of the crossover.
In the event that your speaker has the crossover OUTSIDE the speaker box, you should check ( as always ) with the manufacturer of the speaker to see how it can be changed to suit your needs. Remember to always read and follow your owners manual. Good luck....Rob
Posted on Mar 03, 2008
Hi,i hear alot about bi wireing could someone explain what it actually is used for and what's it meant to do could I'm thinking bout trying it on my speakers?
It's a big job, but the results are great. Bi amp-ing is where the tweeters and mid range speakers are separated and connected to separate amplifiers. You'll need to have the correct gear before messing inside your speakers. You'll need to have another amplifier. Not knowing what amp you have now, getting a stereo signal into the second amp may be a problem since you'll need a line level signal into the second amp. An external crossover is best. Technically, you could use the ones in the speakers, since you'll be removing them anyway. Now for the speaker mods: On the panel where the posts for the speaker wires are you'll need to install another set of binding posts. We're assuming you have separate subs. Open the speakers and remove the cross over. The wires from the original posts should now connect to the mid range speaker. Add wires from the second set of posts and wire it to the tweeters. Now connect the output of the amp to the removed cross over and wire the mid range out on the cross over to the posts that connect to the mid range speaker. Do the same for the tweeters.If you have three way speakers, you'll have to run a 3rd set of wires from the crossover to the woofers in the cabinet using another set of binding posts. Controlling the volume on the second amp will be difficult since you'll have to adjust it manually. Remote control volume level will be lost on the second amp.
Aug 08, 2015 | Audio Players & Recorders
Adcom amp 5802 running hot
It should run hot to touch at idle, about 120F, because it is MOSFET type amplifier.
Mar 23, 2013 | Adcom GFA-5802 2-Channel Amplifier
Adcom GFA 5500 'mechanical' hum from amplifier
Possibly. Most amps filter out line hum via low-pass filters. If you can locate a schematic, those would be the caps to check.
Apr 24, 2010 | Adcom GFA-5802 2-Channel Amplifier
I turn on the ADCOM GFA-5802 amplifier... ...The power light comes on, but does not heat up nor output sound
Have it serviced. Do you know what GFA stands for. People at Adcom do have a great sense of humor. Take it only to a high end audio servicer. Contact Adcom. This is good stuff you wouldn't want a hack working on it.
Nov 23, 2009 | Adcom GFA-5802 2-Channel Amplifier
Adcom 7500, Adcom 5400(bi-amp), Marantz AV-9000, Dakiom HA103
Try just the power amp on ..nothing connected
no Dakiom thingy either. It's a matter of elimination. Start at the output device and work back. Keep the Dakiom out of the loop.
If there's hum with just the Adcom..then it's the ADCOM
Mar 25, 2009 | Adcom GFA-7500 5-Channel Amplifier
Can you bridge an adcom GFA-5802 power amp?
Running an amp in bridge mode requires a specific circuit design. It is not possible to combine 2 amps in this fashion.
Dan
Mar 02, 2009 | Adcom GFA-5802 2-Channel Amplifier
ADCOM GFA 5802 POWER AMP NO SOUND, BUT POWERS UP.
Remove the output transistors and measure each of the sets of 3 pads and report the voltage readings here. I suspect that you have either a blown driver circuit or output transistors. The voltage readings will give me an idea on where to start looking for specifics.
Thanks,
Dan
Nov 11, 2008 | Adcom GFA-5802 2-Channel Amplifier
Proper mode settings
Hi bongodboss
The user manual for this amp has good instruction on how to connect it. You can download a copy from here.
Page 9 has info about using the amp for "bi-amping" The amp is only a stereo unit, so to do a 3-way system, you will need at least 1 amp mono in bridge mode for lows, and other stereo amp for mods, and another stereo amp for highs. You could use the internal low pass filter for the bottom end, and a 2 way crossover for the mids and highs. Much simpler doing a 2 way system with composite bins for mids and highs, and subs for lows. You only need the 2 amps and use the low and high pass filters inside the EP2500. If you need anymore help on this, I am happy to talk to you more.
regards
robotek
Jul 10, 2008 | Behringer EUROPOWER EP2500 Amplifier
Problem with the setup of the mono bi amp feature using peaveys cs3000h amplifier
My recommendation would be to double check the back of you crossover and make sure everything is hooked up correctly. If you crossover is convertible like my DBX223 xl is from Stero to Mono and Three way to two way the connections on the back changes roles.
Nov 18, 2007 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
296 people viewed this question
 Grubhead
Grubhead
