Question about Garden
Murray 10.5 HP 5 year old Snow Blower is dripping some reddish fluid. I notice occasional drips in the snow. reddish brown. Does not look like motor oil. Motor oil is full. What is the most likely source of the leaking fluid?
  • 1 more comment
  • hungarian Feb 07, 2010
    Small amount of leakage is tolerable? Eventualy it will run dry even 1 drip at a time. Can it be refilled. Also, This snowblower has received limited use. Only one forward gear engages (approx 3rd gear). If I put it in reverse, it stays in the same forward gear. I is always in this same gear.
    its not a hydrolic transmission is it? Could it be the linkage?
  • hungarian Feb 11, 2010
    Its a NorthStar serial # 7529935231F096 model # 629118X0A. Only one forward gear works and no reverse gears work. Also, where can i get an owners manual on line? Thank you.
  • 11,896 Answers
The fluid in the transmission is what you are seeing. It's like axle fluid or fluid for manual transaxle cars. It's in the tranny of the blower. Either the seals from engine to tranny or from tranny to wheel axles seals are leaking a little.
Posted on Feb 07, 2010
  • 2 more comments
  • Nate Stansfield
    Nate Stansfield Feb 07, 2010
    Sounds like your gearbox is already low or dry. There should be a fill plug somewhere on the gear case to remove and fill with gear oil
  • Nate Stansfield
    I'd use 90W in the gear box but keep an eye on the fluid level
  • Nate Stansfield
    What model number is you machine? I really don't think linkage would have anything to do with the fluid leak but may help change gears better. I could better tell you if I know the model & series numbers
  • Nate Stansfield
    Nate Stansfield Feb 11, 2010
    You can get a manual here:
    http://www.snowblowerguide.com/snow_blow...
    If you see any linkage, try to adjust it. As far as I am told, this isn't hydraulic.
I want a manual for a Murray ultra 24" 8 hp snowblower
I believe this is what you're looking for.
https://lawn-garden.needmanual.com/murray-walk-behind-1695539-8-0-24-inch-dual-stage-snow-blower-owners-manual.html
Apr 03, 2017 | HP Garden
I need a new starter on my murray snow blower.I bought it in 1998 new 10 HP
wow a 98 !!! well if your local parts place can get you one , fantastic!! me id take old one off and take to a automotive starter rebuild shop have them fix old one , reinstall it back on
Feb 23, 2015 | Garden
What is Murray the recommended oil for the model 630104X35 Snow Blower?
PLEASE USE A 5/30 WEIGHT OIL FOR WINTER USE . WITH THE COLD WEATHER THE MOTOR WILL TURN OVER MUCH EASIER
Feb 14, 2015 | Garden
Snow blower Transimisson
consider this
$160.00 for a transmission for a machine that you want to keep or 5 or more times that for a new unit
check other makes for a transmission that will adapt in or see if there are wreckers /junk yards for mowers /blowers in the area
Nov 15, 2017 | Garden
Not getting gas
The bulb usually doesn't feel that way, you're thinking of a small 2-cycle machine where the bulb will fill up with fuel and offer resistance when pushed. A primer on a snowblower is merely to get fuel flowing to the carb from the tank, whereas the bulb on 2-cycle items actually purges air from the fuel circuit. If you keep pressing the primer you should see fuel drip from the carb inlet. Btw, if you see where an air filter might be on other motors, a little metal cup looking thing, try removing the bolts and flipping it over so the fuel drips out easier and snow doesn't have the chance to fall into it if it were facing up. Once you see fuel dripping out, provided you ran it dry last season when you put the blower away and the carb isn't gummed up with varnish, it should start on full choke. Give it about 3-5 seconds and move it to half choke. Once it seems to want to run on its own, open the choke completely and you should be warmed up and ready to go. Also always remember to let engines idle a bit to cool down if you've been running them at high rpms.
Nov 11, 2013 | Mtd Yard Machines 24" Two Stage Snow...
Hello, I have a SNOW KING snow blower with a Tecumseh 5 h.p. motor (Tecumseh motor model# HSSK50) I bought this snow blower way back in the day from K-MART, "brand new" and one year after...
I would check the intake gaskets to the head first. It is possible that you have a leaking gasket or seal affecting the performance. Your snow blower is set to run on the rich side so it will actually run with the carburetor hanging loose off the side of the motor before it quits running (happened on my Toro 421). Try a top end gasket set and a carburetor clean first (could even be a leaking head gasket). All of which I am sure you can handle yourself.
Feb 04, 2011 | Agri-Fab Agri - Fab Snow Blower - 42"
Was driving thru a snow bank,when i got pass it my steering wheel was very stiff,so i pulled over and noticed a light brown liquid dripping on the behind the driver side front wheel
POSSIBLE POWER STEERING BELT CAME OFF AND WITH YOU FORCING THE VEHICLE TO STEER IT PUSHED OUT THE POWER STEERING FLUID. CHECK STEERING BELT,HOSES.
Dec 30, 2010 | Nissan Sentra Cars & Trucks
I have a Yard Machine 5.5hp 2-stage snow blower. I bought it used but I think it is a lightly used 2004+-. I use the primer bulb and it will start within 2 pulls, runs beautifully. I slowly open the...
The running time seems to indicate a plugged fuel tank vent. Try opening the cap to see if that will allow continued running. Many engines have the vent within the cap itself, while others vent from the air cleaner through a line. Ignore the fuel drip on the adjustment screw. Hope this helps!
Dec 27, 2010 | Garden
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
1990 Volvo 740 GL Wagon Leaking Transmission Fluid
the trans pan might just need a touch up on the bolts , cold weather will shrink the gasket a little bit , if you cant do it yourself , find someone thats handy to just touch up the bolts 1/4 to 1/2 turn on any that will move easly good luck
Jan 17, 2009 | 1999 Volvo S80
Garden Logo
70 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
