Question about Toshiba Satellite A135-S2276 Notebook
Help please! help. while downloading my loptop hanged then i turned off manually and when i turned it on the comp is asking for a password.. they say that the password asking is the bios password.. i cannot even access the cmos setup.help
  • eiyee Feb 22, 2008
    technomanic, my laptop is toshiba satellite A135-S22716.. i tried the phoenix and shift thing.. it did'nt work..
    Problem Solver:
  • 10 Answers
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
Posted on Feb 22, 2008
  • 1 more comment
  • sufiyan kakingarae Feb 22, 2008
    The default password for the BIOS is phoenix. Phoenix is all lower case letters. Another thing you can do is as the system is booting up, right before you get to the Toshiba splash screen, you have to tap on the Shift key
    Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw. try it
    Short out JOPEN1" it simply means discharge/drain remaining power in the circuit. Simply connect these two points with some kind of metal. This will connect these two points and cause a "Short" to occur. You can use two screw drivers, a needle nose pliers, or simply a tweezers. Good luck!!!
Dear sir i want to use my netgear wgr614 router as access point. please give me suggestion how can i do that
In Your web browser type in 192.168.0.1,it will ask you for a user name and password,user name is admin and password is password,once you enter the netgear setup utility find the section that ask you if you would like to use as an access point,check it,save changes-you will have to download the user manual on detailed step by step instructions from netgears website in order for it to work-i would download the user manual before you do anything at all and read first what has to be done-Good Luck-Access points are not easy to configure and must be connected via an ethernet cable when doing the initial setup-Have Fun
Jan 22, 2011 | NetGear WGR614 Wireless Router
My aspire5600 loptop password i forget asking me user name welcome and password i dnt knw how can i open my loptop
hi there you can see a option in small text " forget password?" click there & give the asking question answer. if you not done then let me know.
Jan 17, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
TOSHIBA EA60-156 BIOS PASSWORD
There is a jumper located on your motherboard that you need to use to reset your bios password. You can generally find this information in the manual that came with the notebook. If you don't have the manual you'll need to go to the toshiba website.
Please note that resetting a jumper on a motherboard is not the easiest thing to do on a notebook computer. You're talking about taking apart and putting on eback together. Be very careful not to let any static electricity hit the machine.
Jul 07, 2009 | Computers & Internet
Keyboard not working
is this a windows login password or a boot password
you should have Fn key on keyboard
and another coloured key to correspond for turning on keyboard press Fn and the other key simultaneously
Could be fn f3 keys
if you just bought you may find it in your manual
please let me know if you still need help
if you have a switch above scroll pad you may have shut that off but all models don't come with that option
Feb 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
I have windows vista on my new rent to own used comp, and I had just changed the name from rac to Mrs. Winn and the password from rac yes they had the password the same as the name but I had changed it and...
Yeah it's quite easy to remove/change the Adminsitrator Password . Just Download the NT Password Removal Software & Follow the Instructions from THIS website.
Dec 06, 2008 | Computers & Internet
HELP!!! Cannot start VAIO ARG230G
do safe mode, and find out if your disk is clean or overly fragmented
Mar 12, 2008 | Computers & Internet
Help pls
only way you can reset bios password is to reset the BIOS . to do this
*if its an desktop
open tower , inside the tower you'll see motherboard
look out for battert (wich is size of nickle)
remove the battery and wait fo few second
then insert it back
reboot................
*if its an laptop , let me know model no and make
Feb 22, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
204 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
