Question about Microsoft Xbox 360 Console
I was playinfg and i turn it off for an hpur and when i tur it back on. the screen went E 73 i call for them(xbox) to fix it and they chargin me $130
  • 28 Answers
Xclamp failure or overheating chips (fix using pennies or use x-clamp repair kit found on E-Bay)
Posted on Feb 07, 2010
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
When i turn on my xbox 360 it turns to a black screen and says i have error E73 and when i went to Xbox.com it didnt say anything about it
Apr 14, 2010 | Microsoft Xbox 360 Console
I have the error 73 showing on my screen. how can
E73: General Hardware Error: Ethernet port... this error is caused by a problem with the Ethernet port. Try this troubleshooting. Remove the A/V cord from the back of the XBox 360. Stick two sticks into the fans to prevent them from spinning. This will cause the system to overheat within five minutes. You will know its done when the first and third quadrants light up red on the system (indicating the system has overheated). Unplug the system, plug it back in and turn it on to see if it was successful. (Note: While this method does not void your warranty, if your XBox is still under warranty I suggest sending to Microsoft to fix.
Thank you for using Fixya!
Apr 12, 2010 | Microsoft Xbox 360 Console
Xbox 360 E73 error. What do I do?
Apr 07, 2010 | Microsoft Xbox 360 Console
How do i fix my xbox 360 e73??
When turning on the Xbox 360, a red light would be flashing at the fouth section of the Ring of Light. You should then recieve a ghost screen indicating an error E 73.
You recieve a screen error E 73 and section 4 of the RoL flashing red. This type of error was caused by a General Hardware Error relating to the Ethernet Port not functioning correctly or became faulty and unable to operate even with or without an Ethernet Cable connected to this port. The secondary code would be identified as 1021 for faulty ethernet port. I believe that there is no fix at the moment. If you encounter this error, I would suggest call 1-800-4MY-XBOX or visit www.xbox.com/support
The specific type of hardware error can be determined by these hidden codes:
0001, 0002, 0003, 0010, 0011, 0012, 0013, 0020, 0021,0022, 0023, 0030, 0031, 0032, 0033, 0100, 0101, 0102, 0103, 0110, 0200, 0203, 1000,1001, 1002, 1003, 1010, 1011, 1012, 1013, 1020, 1021, 1022, 1023, 1030, 1031,1032, 1033, 1100, 1444 and up
More information about these codes and errors, visit this webpage:
http://forums.xbox-scene.com/index.php?showtopic=484726
  • Note: There is known to be a temporary fix for this problem but is not recommended if the device still has available warranty on it. Doing so will avoid it's warranty, thus for you will pay $100 if sent for repair.
The Sticks Method:
  • Requirements: Xbox 360 (Power Cable and Composite/Component/HDMI Cable), two sticks (Like toothpicks, swabs)
1.) Turn off your Xbox 360 and unplug everthing.
2.) Get two sticks (Something like toothpicks or something that could fit in the back of the Xbox 360.
3.) Insert each stick to jam the two fans at the back of the Xbox 360 to prevent it from spinning.
4.) Plug back cables (Power and Cable connecting to TV; the RRoD will not appear unless the cable to the TV is connected).
5.) When RRoD appears (One Red Light), wait for about 10 to 15 minutes or maybe less for the Xbox 360 to overheat.
6.) At this point, you should get two red lights (Resembles Overheating Error) so remove the two sticks so that the fans will spin in an increased speed. After a few seconds, the Xbox 360 will turn off to cool down (RRoD will still appear).
7.) Unplug only the cable connected to the TV. You can unplug the power cord if you want to. Then let it cool for about 30 minutes or so (Feel the Xbox 360 if it's cool or still warm)
8.) Replug all wires and turn your Xbox 360 on.
The Xbox 360 should now be able to boot to your Xbox Dashboard. I don't know how this fix works but it's only temporary. Note that doing this continually would cause it to now work even if you try to redo this fix again and again. Doing so would make other hardware components to fail permanently such as the GPU for example.
If this first temporary fix did not work, do the second method: The Towel Trick. You can find the tutorials in Youtube. Again, this is not recommended if you have warranty left and never do this continually. Your Xbox 360 would completely and permanently fail after that. if it doesnt help after all this....I suggest sending it to Microsoft for repairs
Feb 05, 2010 | Microsoft Xbox 360 Controller
Xbox 360 error code e73
The Internet Port or Referred as the CPU or GPU is fried and needs to be turned in the Microsoft for repair. No other way that i Know will fix it.
Jan 12, 2009 | Microsoft Xbox 360 Console
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
My xbox 360 wont turn on
make sure ur power brick is plugged in correctly. when u tur n ur 360 on the lite on it should be green
Jul 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
