Question about Belkin (F5D72304F5D7010) Wireless Router
Belkin 54g 2.4 ghz wireless router model # f4d7230-4
When i try and install the software on win xp i get prompted to enter my username and password for internet connection. When i enter these details its says the information is incorrect, yet i am 100% positive that the username and password are correct. Any suggestions?
  • Anonymous Mar 22, 2014
    I entered wrong password now that I am trying to install wireless hp printer it sh how to correct passwordows motorola-3c747 but it shows c9ccf8d0ca2e8d0d431e and it should show 3c7471100754
  • 77 Answers
Hi, Instead of using the softwae disk, try going to the router's config page,
Connect your computer toi the router using the ethernet cable that came with it
then click here http://192.168.1.1
the usename is admin and the password is password
Use the basic setup wizard in there to input your isp username and password
Posted on Feb 22, 2008
I don't have the cd
You don't really need the CD to setup a router but it does make it easier for non technical users.
##### DISCLAIMER ######
My solutions are generalized solutions and the actual solution may deviate slightly from what is actually posted in this solution. If you are unable to complete a step PLEASE COMMENT WITH THE EXACT MAKE/MODEL AND I WILL POST THE SPECIFIC STEPS (if you already have provided the make/model just comment what step you need more help with).
##### END DISCLAIMER #####
First obtain your IP Info
GETTING YOUR IP INFORMATION
*** Info presented in [] will distinguish between a windows XP step and a Vista/7 step. A bracketed step will be in the format [WinXP Step/Win Vista/7 step] ***
1. Click on the [Start/Windows] button.
2. [Click Run/Go to next step]
3. Type cmd
4. In the command prompt type "ipconfig " minus the quotes.
5. Write down the ip address and default gateway address. They will be in the format ***.***.***.***
Now time to configure the router
1. Plug in a en ethernet cable(looks like a extra wide phone cable) into the computer you want to configure the router with.
2. Plug the other end into one of the numbered ports on the router.
3. Open a web browser and enter the default gateway address and hit enter.
4. If prompted for username and password try one of the four combos (username/password) admin/ , admin/admin , /admin and both blank.
5. Once logged in you will want to change the username and password this is generally under the "basic" or "general tab" and rename your wireless SSID
6. Only other thing you should setup is the wireless security this is generally under a tab called "security" or "wireless security"
7. Step the encryption to WPA2 PSK. Make sure to make the password with Upper & lower case letters, numbers and special characters. It's ok to write it down.
Now connect to the network you named and enter the WPA2 password and your done.
Comment if you need additional assistance.
Aug 04, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I need to connect my ipod to internet but i need my code that is lost
To retrieve the WEP "code"..... you will need to access the Router with a computer connected to the ethernet port on the router. You will need the Username and Password for the Belkin.
You should be able to access the unit from your browser.... by typing in the following IP Address in the address bar.....
192.168.1.1
Most of these wireless routers have "default values"
Username= admin
Password= password
If Belkin does not respond.... you may need to push in the reset button.... with the power on. This will reset all values to default. Then just try again....
Under Wireless Options... You should see the SSID and the WEP Code
Nov 05, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I need to make my bilken 54 router secure
look on the bottom of the router there is a stricker with a website, go to it enter the username and password found on the sticker. Once in you should be able to edit your security settings
Feb 23, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
How do i access my belkin 54g settings
To access in your router, open a blank Browser page and type :
http://192.168.2.1 normally it's this ip :)
(note that A lot of routers setup pages are accessed through [192.168.1.1]).
username : Admin and at password leave it blank otherwise Type : admin
Oct 15, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Installing belkin wireless router
1. First, Begin by resetting your modem, the reset button can be found on the back of the modem, underneath the power button.
2. Once the modem is reset, do this for your router, and when you are finished connect the cable from your Modem into the "internet" or "modem" port on the back of your router.
3. Now run a cable from port number 1 on your router, to the back of your originial computer. Give this a moment to sync.
4. Now open your web browser and type in 192.168.2.1 and hit enter, it should prompt you for a username and password, enter "admin" in the username, and leave the password blank. You will now see the router's status page.
5. Now configure the Router according to your ISP setting.
Jul 29, 2009 | Belkin (F5D7231-4) Wireless Router
I have a problem I just bought GE 2.4 GHZ phone
I'm not sure if your phone has a channel selection or not, but I know your router does. This issue happens because both wireless internet and cordless phones operate on the same frequency. To change your wireless channel you need to go to your router settings which should be at 192.168.2.1 for a belkin router. To get here you simply type that number where you would normally type a web address in your browser. You enter the username and password and go to wireless settings. Under there you should see something along the lines of channel. The most common channels are 6 and 10, if your router is already on one of these, try another channel. Just keep doing this until you find a channel that your phone is not using and your router should work just fine now.
Jul 20, 2009 | Linksys WCG200 Wireless Cable Modem 54G...
Cannot connect to wireless printer, pc is connected to 54g direct
its a bit complicated but we can try out.find out the ip address of teh wireless router,,put it in the address bar and click entera box will com for a username and a passwrd.if u havnt chaged anything.then default username and passwrd is{Belkin
IP : 192.168.2.1
username : admin
Password : (Blank)
try this and u will see a belkin page,,search for connected devices and u will see the printer option there.in the mean time install the drivers of the wireless printers on the desktop pc,,follow the prompts on the installation very carefully,,its easy and then make ita s a default printer,thats it
Feb 07, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
It wont connet to my belkin wireless router
Hi...to find the password, or network key:
1) Login to your router.
To do this, open a web browser on a computer, as if about to view a web page: then type the router address, http://192.168.2.1 in the address bar.
2) You should see a prompt asking for a password. Just click 'submit' button if none has been set: otherwise, enter the correct router login password.
3) You should see the router user interface. In the left hand menu, under Wireless, click Security.
The 'Pre-Shared Key' or PSK you see there is the network key (password) you need.
Please come back to Fixya if this doesn't work or if you need help with any of it. Good luck
Jan 11, 2009 | Belkin (F5D7230-4) Router (587009)
I'm trying to connect to my belkin54g router with another laptop - how do I find my wep or wpa?
First make sure you can see the router in your Available Networks. You can do this by double clicking the Networks icon at the bottom right hand corner of your screen.
If you can see the router on the list, double click on it, and if it is unsecured, then you should be able to connect to the internet. If it is 'secured', then you have to enter the Username and Password to gain access.
Or you could type 192.169.0.1 into your internet browser URL box on the laptop. This will ask for the same Username and Password. The default Username is usually 'admin' and the default password is usually 'password' (or 1234 on older models). If successful, you should be able to see the routers settings, and diagnose if your router is properly connected to the internet. If it seems to be connected, and the Username and Password are being entered properly into the laptop when you try to connect to a network, then it can only mean that the laptop's wireless card/adapter is not configured properly on the laptop.
I hope that helps :)
Chris
Dec 17, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Setting security fetures
Hi chelsea
Solution: WIN XP
goto start>>
click run
type cmd
type ipconfig
check what is ur default gateway
then goto internet explorer
type the default gateway in address bar
YOUR belkin router homepage will come up
If it asks you for any username and password
U will have to contact belkin to get that...
after entering the username and password
u will be able to check the configuration setings
find the firewall settings on the router ( if ur router comes up with inbuilt firewall )and change it to "high"
It could help
Other wise keep on changing the username and password for the router
Feb 17, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D72304F5D7010) Wireless Router Logo
515 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
