Question about Brother CS6000i Computerized Sewing Machine
When threading the macine coming down half way there is a wire that is not in place. don't know what to do?
How do I thread the bobbin of a brother xr-35
fit the bobbin into the bobbin case and feed the thread to the outside through the opening. it does not matter which way round the bobbin is in the case, then insert the case into the machine make one turn with the macine so that the threaded needle drops through the plate. when it comes back up it should pull up the bobbin thread with it. then take the two threads and pull them back and insert your material to be sewn.
I hope this was useful.
Feb 12, 2015 | Brother Sewing Machines
Singer 5050c top thread coming out of tension control during sewing
What if you get a thread stand? does it happen when stitching vigorously or normal stitching? Thread stands helps keep tension and avoid thread jumps etc...
Nov 15, 2013 | Singer 5050 Mechanical Sewing Machine
Kenmore 385. 15343600
Remove bobbin, presser foot, needle. Tip machine back on towel gently. Unscrew plate--don't lose screws! Do not service in presence of children and curious pets. Put foot pedal next to you on tabletop. Use Zoom Sewing Machine oil. Any part MOVING that are NOT gears get one drop oil. Any DRY ONLY gears get dab of Singer sewing machine lubricant. Replace screws. Secure screws. Open left front compartment & one drop oil @ top of needle bar. Open race shuttle (where bobbin case fits in). One-half drop oil of on oscillating hook (bottom left - hand corner...smear that oil around! Insert NEW needle all way UP in needle bar groove, flat needle shank toward back. Turn handwheel towards you and raise. Raise presser foot so that threading locates all tension slots a's you pull thread TAUT from spool to each tension slot and left to right through silver, metal take-up lever, and down to tension bracket, pass needle, then pull 6" thread towards you and thread from FRONT to BACK of needle. Place bobbin into case and "thread" it. Set presser foot on DOWN position. Turn handwh towards you, dipping needle into needle plate. Make loop with bobbin thread, pull towards you. Place a good 7" underneath presser foot (both threads). Let machine RUN on 24" scrap to distrubute oil/lube. That's it! Jimmy
Apr 05, 2012 | Sewing Machines
The macine said it was an E6 error thread jam which I completely cleaned the bobbin area (not much there anyway) but I still cannot get it to not jam the thread on the botom. I have changed needles also.
Hello
This code tells you that the motor locked up because the thread is tangled. Untangle the thread, make sure the machine is threaded properly and that the proper tension is set before continuing.
It could be that the bobbin is being put in upside down check to make sure that you do not need a bobbin with a magnet on one side. also make sure there is no thread tangled inside the bobbin housing it will cause the timing of the machine to be off and cause issues with your needle picking up the bobbin and thus cause a mess inside you bobbin housing
Jul 11, 2011 | Brother CS-100-T Computerized Sewing...
Why does the 4th thread keeps breaking on my serger? I've re-threadedi it a dozen times carefully following the diagram. What am I doing wrong?
Most likely it is either your tension on thay thread being too high, or the needle is too big for the project you are working. Lower that tension, use the next size up needle, and thay should fix it. Also, I STRONGLY suggest only using maxi-locks thread. They are more expensive than other serger threads, but they are always half-price at hancock... Any other thread I have tried using causes breakage, especially on the the lower looper (the 4th thread). Although, of you keep the tension low-below 3 or so, you should be ok. If these tips don't help, I would also check your cutting width, if your machine has an adjustable one. If it is leaving too much gabric to the right of the needles, out is conceivable that this is putting too much pressure on the threads. Let me know if this helps!
Jun 23, 2011 | Simplicity Sewing Machines
How to thread the singer cg590 sewing machine??
First, be sure your bobbin is in correctly, place it with the thread running counter-clockwise (the tail will be off to the left), and drop it into the bobbin case. Pull the tail toward you and make sure it catches on the silver catch closest to you by pulling to your left then away from you (toward the feed dogs). You should now feel some tension on the thread, this is good.
Be sure the presser foot us up and the wheel is turned so the needle is at it's highest point (neutral), then put a spool of thread on the spool holder (behind the machine above the motor) with the thread catch (a little notch) to the right as you put it on. Put on the thread holder (a plastic donught that holds the spool in place). The spool should not move but the thread should come off of it freely.
Bring your thread through the plastic catch on the back of the machine (near the center) by passing it underneath and pulling upward and to the rear. Pull it to the front over the top of the machine and pass it through the bottom of the small metal holder (not the round part, that is for winding the bobbin). Bring it down in front of the machine to the tensioner, passing it around the bottom of the tensioner then pulling up so that the tension is engaged. Don't worry if you don't feel tension, that's normal if your presser foot is up and needle is at the top. Pull the thread up to the top of the machine and through the receiver then down toward the needle. There is a double loop just above the needle, thread through it then thread your needle front to back.
Be sure to pull up your bobbin thread and hold both threads as you start to sew.
Feb 22, 2011 | Singer CG590 Mechanical Sewing Machine
Model 3205 FA not picking up bobbin thread, needle goes down but doesn't pick up bobbin thread, needle not bent, macine was working fine then all of a sudden bobbin thread stopped. Can't even pick it up to...
- check ifu are using same needle model.
- check hight of needle bar is ok
- check timming between needle bar and hook.
- check if your material is very stritch or no
- check blad point of hook is ok or no
best regards
Aug 15, 2009 | Necchi Sewing Machines
How do you thread a singer 9836c machine
I have this machine and the manual but it will be difficult to explain without the diagram. Here are the instructions without the diagram ... I'm assuming that you know some parts of the machine i.e. the foot etc
NB. thread the bobbin FIRST - points number 8 onwards....
1. Raise take-up lever to highest position on machine by turning the hand wheel towards you and make sure the presser foot is raised.
2. Place spool of thread on the spool pin at the back making sure spool cap is firmly in place to keep it on.
3. Take thread and place through the thread guide (plastic bit same side as spool pin) a under and over action. Across from this guide is a small metal wheel on top of another loop pin on the top at the front of the machine. Take the thread and put through the loop pin. 9Thread should come out on top of the pin towards you).
4. On the front of the arm is a tension wheel numbered between 0 - 8. The thread should then be placed down the front of the arm, underneath the tension wheel (behind the body part of the arm not under the wheel) and lifted up to catch the tension spring unseen behind the wheel. It should then be threaded through the eye of the metal piece (that moves as the needle goes up and down).
5. The thread should then be passed down the gap in the body work and down through the middle of the metal spiral loop in the front near the needle.
6. The thread should continue down through the horizontal clip just above the needle.
7. The needle should be place with the flat part at the back and held firmly with the screw. The eye of the needle will face you. The thread should then be threaded through the front and out the back and under the foot leaving a six inch tail.
Your thread should now come off the spool move towards the left through the plastic guide, across the top of the machine at right angles, through the metal loop; down the front of the machine (you can't see the thread as it sits behind the body) and reappears through the metal arm hole that goes up and down with the needle. It should then come down through the metal spiral and behind the clip above the needle, through the eye of the needle and away from you under the foot.
8. The bobbin needs to be wound. The bobbins are particualr to each make of machine. So only singer bobbins can be used on Singer machines. The bobbin winder is the metal pin on the right on the top of the machine.
9. To wind the bobbin. Place the bobbin over the metal pin nad push firmly down. It is located on the top on the right hand side.
10. Place thread on the spool pin as before and thread the cotton through the plastic thread guide.
11. Take the thread as before but rather than going through the metal clip on the top at the front, place it anti clockwise partly round the metal wheel on top of the metal clip (don't go all the way around) and across to the right where the bobbin has been placed.
12. The thread should be wound clockwise as many times as required not to slip off when the thread is automatically wound with the electic foot peddle.
13. Push the bobobin manually to the right along the groove in the body and press the electric foot peddle. Bobbin should wind moving the thread up and down (not necessarly evenly) and filling the bobbin. Fill about 80%. Leave a six inch tail.
14 Pull the plate forward under the needle. Place bobbin in its slot. The thread should be in a clockwise direction and when the bobbin is placed catch the thread under the groove found on the left at the top of the bobbin case. Close the plate with the thread coming out above in the slot under the needle.
15 Manually turn the hand wheel a couple of times until you can see the bobbin thread making a loop with the stitch thread and pull through.
16 Both threads should be under the foot and away from you.
17 Tension normally is around 5 -6 on the tension wheel with standard cotton and polyester cotton thread. To tighten the tension the number should increment upwards.
Machine is a cracker and according to my local shop never goes wrong. I have had mine since 1999 and that's true.
Hope this helps.... I would send you the manual but I'm not sure how you keep email addresses private.
Good luck.
Jun 29, 2009 | Singer Sewing Machines
Brother CS6000i Computerized Sewing Machine Logo
14 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
