Question about Dmm Vision Fitness T9500 Treadmill
On/off light comes on but control panel is dark screen. Not responding. Belt was very hot last useage
    Problem Solver:
  • 18 Answers
It may have tripped thermal over load. Check for a manual reset on the lower front by where the cord connects to treadmill.
Posted on Feb 07, 2010
Sparform hot tub blower won't turn off
When an appliance will not turn off, no matter what you press on the control panel, you have either a non responding (dead button) topside control panel, or your topside panel did receive the message to turn it off and the circuit board is not responding.
  • If you have some kind of indicator light when you press your Jet/pump button, if the topside panel is operational and does actually receive your request to either turn on or off an appliance, an indicator will appear - either a light or icon.
    • If one does appear when button pressed, then dis-appears when pressed, that means your panel is good - as it is responding to the pressing of the associated button.
      • Bad circuit board
    • If nothing appears when you press the button, no lights or icons - indication of topside receiving your request, then you you have a dead button.
      • Bad Topside Control Panel
May 18, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
The sreen does not light up when turned on
remove back panel and check fuses for simple fix but replacing fuse may further damage already damaged or burnt components.
Inspect boards for burnt components and inspect the solder joints of hot areas typically noticeable by dark areas on the boards.
Jan 21, 2014 | Televison & Video
Profile GE PS123Sc about 6-7 yrs old. Freezer side seems fine. Fridge side is too warm, but is cooling (about 40F). Fridge side lights are intermittent and control panel at top is intermittently dark or...
Sounds like a bad motherboard and probley need control board. You can put in self dianoss. Press all the buttons on panel for 5 seconds. This will start the program. It will check all sensors. Come back with codes and I will help you. Wait to hear from you. I hopes this helps. david_gra582
Aug 27, 2011 | GE Profile PSS26NGS Side by Side...
I have the 691tr-icc6 outlet/toggle. I would like the switch to control the outlet below it. So I can turn on and off the outlet as needed. , Where do I put the black and white wires that come to the...
You have switch plug combo with dark screws, brass screw, and silver screw.
Dark screws are for black Hot wire coming from breaker box.
Brass screw is wire going to Load that you want to turn on-off.
Silver screw is for white Neutral wire coming from breaker box.
To set up so switch controls outlet, you need 2 dark screws on one side of device that are connected by break-away fin.
Remove fin so dark screws are no longer connected.
One dark screw goes to switch, one dark screw to outlet.
Hot black wire connects to dark screw for switch.
Connect jumper wire from brass Load screw to the dark screw for outlet.
Connect Neutral wire to silver screw.
To test for Hot and Neutral:
Separate wires.
Turn power ON.
Test each wire to bare ground wire, tester lights up on Hot.
Hot is identified.
Test Hot wire to all other wires except bare ground, tester lights up on Neutral.
Mar 28, 2011 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
Feb 12, 2009 | Hannspree HANNslounge 32 in. LCD HDTV 32
On a trip ,reached destination turned off gps will not come on. plug it in light comes on but screen is dark held on switch for one min will not respond tryed for last 3hrs no response
Take out the memory card and then reset the tom tom (with a pencil or something sharp), and then put the memory card back in and push the on button. let it charge up for as long as you can.
good luck
chris
Dec 14, 2008 | Tomtom Go Plus GPS Receiver
Dark picture image, dosen't respond to briteness control
are you able to see the picture in a dark room ? does it appear bright enough then ? if so the lights behind your screen have dimmed or gone out completely. this may just be the power supply for the lights or your lcd panel may need to be replaced
Nov 19, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony vaio screen dark then light
your laptop inverter is going bad. need to replace. you can get it on ebay cheap. the inverter is responsible you the lighting up of your screen. thats the solution REMEMBER TO RATE THE SOLUTION
Apr 09, 2008 | Sony VAIO VGN-N130G/W Notebook
Dmm Vision Fitness T9500 Treadmill Logo
134 people viewed this question
Top Dmm Exercise & Fitness Experts
fretlessbass
fretlessbass
Level 1 Expert
Sportsmith LLC
Sportsmith LLC
Techmotionusa.com
Techmotionusa.com
Are you a Dmm Exercise and Fitnes Expert? Answer questions, earn points and help others
