Question about Loewe Aconda ACO9303 30" TV
TV picture settings only show panorama and 16x9 options, all other options have mysteriously disappeared. We are getting an incomplete picture (appears to be a zoomed in picture of what is supposed to be on the screen). Please help, Super Bowl is coming on very soon and we won't be able to see the score at the bottom of the screen :-( THANK YOU, Amanda 512 852-9668 Amanda_Slate01@yahoo.com
  • 4,472 Answers
Well this all depends on what source you are using? Is the tv hooked up to a cable box? Have you checked the cable box settings to make sure the aspect ratio hasn't been changed on that as well.
Thank you,
Lee
Posted on Feb 07, 2010
How to resize picture on a magnavox mwc20t6
Look for a setting called Aspect Ratio. It will include options like 4:3, 16:9, Zoom 1, and Zoom 2. Then click through the options to select the correct one for your program. Usually older SD programs will use either 4:3 or Zoom 1, while HD programs will be set to 16x9 for Widescreen hi-def viewing. There should be a button on your remote labelled Aspect Ratio or Picture that can toggle through these image modes.
Nov 26, 2014 | Philips Magnavox MWC20T6 TV
Tip
Curing the "black box" on some TV channels
Here's the symptom: A mysterious black box covers some or most of the picture on your TV, but not all the time. It may not show up on all channels, or sometimes it disappears only to come back later.
No, it's not the picture tube, it's your closed-captioning. Somehow your TV has been set to "text mode", and the screen is being cleared for text that isn't there. On channels or shows where captions aren't being broadcast, there's no box. But the box returns when captioning is being sent.
Many TV set remote controls have a single button to set closed-caption modes, so it's easy to set a TV to "text" without knowing it. (Especially when you have kids who love to press buttons!) Then when the box pops up, it's a mystery.
Simply press the captioning button on the remote, or use the set's menu, to cycle through the settings until you turn captions off. No more box!
on Jan 31, 2010 | Televison & Video
It shows picture not in full screen like the movies black screen at top,in middle is the picture,black screen at bottom
If this happen on DVD's it is because the DVD is formated to Widescreen, 16x9 size, your TV is 4x3 size. Unless the Menu has an option of Picture size, or Format, to set to Full screen. there is nothing you can do other than be sure to check the DVD for picture format size before purchasing.
Sep 28, 2009 | Hitachi 43F300 43" Rear Projection...
42' hd tv has stretched picture makes people look fat
you have a few settings to size the picture as best as it can be sized.
format, aspect and size . try setting the TV (remote) format to full, fill or just.TV size to 16x9.
If also using a cable/satelitte remote set it to 16x9 size, stretch format/aspect and 1080i output. then just press the # key on cable remotes or format key on Sat remotes to size it best on each channel.
with 16 formats available, today's TVs are doing their best to keep up.
hope this helps
Eric
Aug 29, 2009 | HP PL4260N 42 in. Plasma HDTV
I have a 52" samsung that is 14 months old. for some reason it is out of sync. the picture is too wide and does not fit cable shows or dvd's properly onto the screen. tried different picture size settings...
FCC says it only has to display a picture, with 16 formats it tough to get it to ever fit right, use 16x9 or full on TV remote , then 16x9, stretch 1080i on cable box
Jul 27, 2009 | Samsung LN52A650A LCD TV
My picture is zoomed in, the picture is too big for the screen. I've tried a hard reset, and I have the factory remote, but I can't seem to even find the zoom option. how can i un-zoom my tv?
there may not be a zoom option but there should be a ratio setting i.e 16x9,4.3 letter box i had that problem and found it in my display settings my screen resolution was changed to 16x9 zoom
May 26, 2009 | Televison & Video
How to activate panorama?
Panorama shooting lets you create a panoramic picture, using the OLYMPUS
Master software from the provided CD-ROM. An Olympus xD-Picture Card is required for Panorama shooting. If the card is a Fuji xD card then the panorama feature would be disabled to you.
May 24, 2009 | Olympus Stylus / mju 1050 SW Digital...
Hi there When I shoot in 16x9 widescreen with my Canon XL1 the viewfinder shows the same image as when shooting in 4x3. Can this be adjusted. Regards John
It is not showing the same image, it is showing the 16x9 squished down to the 4x3 aspect ratio. I thought I had the same thing at first too. But to check & make sure set up a shot of something square in one or the other shooting ratios. Then go into the menu & set it up on the 16x9 on/off. To make it easier to see the picture hook up to a monitor to see the picture without squinting through the eye piece. Now while you are watching the picture switch the 16x9 on & off on the camera. If you started in 16x9 the square will lengthen from side to side in 4x3, while the square in 4x3 will become squished on the sides. If you can't tell, take a piece of tape [removable tape that is] and make the sides of the box before & after you change the aspect ratio.
Apr 29, 2009 | Canon XL1S PAL Mini DV Digital Camcorder
EEP RESET changed my picture to wide screen.
Go into Menu and look for Video section and find wide,panorama,16x9 and 4x3. gottas be there. then click on normal thnen click on what you want..
Please rate!!
Mar 16, 2009 | Polaroid TTM-2004 20" TV
Mystery Gift Menu Option Disappeared
Reconfigure your wireless settings in the pokemon game *where you select new game or continue*.
Feb 09, 2009 | Nintendo Pokemon Diamond for DS
Loewe Aconda ACO9303 30" TV Logo
Top Loewe Televison & Video Experts
Josh Whitehead
Josh Whitehead
isaac johny
isaac johny
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
