Question about Whirlpool Washing Machines
What's F-21 mean on my front loading washer - Whirlpool Washing Machines
  • 572 Answers
Check drain. check pump for objects
Posted on Feb 07, 2010
What does F- and 21 mean
Error code F 21 means the drain is clogged...follow this advise for the Whirlpool washer as Maytag was bought by them
there is also this site for the washers http://fixedappliance.blogspot.ca/2011/11/whirlpoolkenmoremaytag-more-f02f21-sd.html
Jun 04, 2015 | Maytag EPIC MFW9700S Front Load Washer
What does f-21 mean?on my front loader washer
Please check this video on abut f 21 error code and how to rectify it.
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does a F-21 mean? It wont drain out.
Means long drain. Remove the lower front panel and clean out the drain filter.
Dec 07, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore fHE 2 plus front load washer does not drain and does not complete the spin and drain cycle. Error code f-21.
Means the drain is too long. Under the front lower panel is a sump filter. Remove the filter by turning ccw and clean.
Nov 04, 2010 | Kenmore HE2 Plus Front Load Washer
IT IS SHOWING THE NUMBER 21
What 21 is meaning is Long drain, if the drain time exceeds 8 minutes the water valves will turn off. Press pause/cancel two times to clear display
Jan 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-21 error means What?
F-21=LONG DRAIN If the drain time exceeds 8 minutes the water valves shut down. After 4 mins the Sd(slow drain) error will be displayed, 4 mins later the F/21 error code will be displayed.
Press PAUSE/CANCEL 2 times to clear display
Probable cause/Proceedure
Drain hose plugged/kinked
unplug washer/disconnect power
check electrical connections to pump
and make sure pump runs
check drain pump filter for strings,sand etc
plug in washer If this dont work
replace pump.
Dec 31, 2009 | Kenmore HE2 Plus Front Load Washer
F-21 flashing washer stops
The F-21 means slow drain. There is a filter in the front of the machine, you have to remove the bottom front piece to get to it. The screws are on the bottom. You then will have to open the filter. It is a white tube. Mine was pretty tight. Be prepared for water to pour out. I have had to empty mine twice in the 2 years I have had it. Hope this helps.
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F-21 on my window
F21  mean LONG DRAIN if the dreain time ixceeds 8 minutes the water valve turn off. *After 4 minuts the "Sd" error will be do;[;aied tjem 4 minuts later the        F/21 error code woll be displayed. * Press STOP two times to clear the display.
if this wont work the following mus be done by a technician.
Was this helpful?
May 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
