Question about Fujitsu Televison & Video
My fujitsu plasma is not turning on--the "on/standby" switch stays red. No picture but sound comes through from cable box to external speakers
  • crosenzweig Feb 07, 2010
    no picture on fujitsu plasma tv
    President:
  • 2,923 Answers
The reason there is no picture is (95%, certainty) the loss of the high voltage. The high voltage is what produces the energy for the raster lines upon which the video is modulated.
Therefore, the video and deflection circuits may be working just fine but you cannot see because there is no high voltage to the picture tubes.
Now, it is possible, also that power to the projection tube filaments has been lost, or that the power supply to the biasing voltages is defective or that the picture tube sockets are corroded, but the overwhelming cause among TV sets is loss of high voltage.
Refurbishing the high voltage will probably cost $250 or from anywhere you go. Even if you do it yourself and buy the parts wholesale you will not save a tremendous amount. So, unless you are very handy and know how to troubleshoot, solder, repair and test, I think you are better off finding a good shop for the repair.
Good luck and have a great day!
Posted on Feb 07, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. A plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems. X, Y sustain, buffer boards controls picture, fires the gas, and many others functions. When either of these boards goes bad common problems include negative image, no image, vertical or horizontal stripes on picture, turns on and than turns off, and many more. You’ll need to open the back off the TV and check for any swollen/bulged/leaky capacitors on these boards and replace whichever has gone bad. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
NEC PX-50XM4A 50" plasma tv - I get a picture but no sound. I have my cable box plugged in to the DVI port converted to HDMI going to my cable box but I cant get sound when I plug external speakers in to...
HDMI carries both video and audio.
Do you get video and audio on TV. Just to be sure.
Now are the external speakers powered ?
are you connecting the Speakers to Audio Out of the TV ?
By the way, I cannot see any RCA port that is output port on your NEC plasma. NEC 50XM4 User Manual Specifications The audio input is for audio from dvd for example.
Oct 23, 2013 | NEC Televison & Video
No sound on my fujitsu 50" plasma TV
its not hooked up right your cable box or tv manual should show you how, cable audio out, tv audio in left and right
Jun 15, 2013 | Fujitsu P50XHA10 50 in. Plasma Television
I just got a new power supply installed in my Fujitsu 50in. Plasma P50XHA4OUS and cannot get the sound to work, we've tried everything, please HELP!
Assuming the power supply is exact replacement and you did not have this before--check the speakers to make sure not turned off.
If using a cable or sat box make sure sound not way down or off both with the set and the box.
Last but not least if sound is there with a DVD---something somewhere is set to wrong position.
Apr 27, 2012 | Fujitsu 50 in. Plasma TV
We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Feb 03, 2011 | Fujitsu Siemens PlasmaVision P42VHA40...
No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Sep 27, 2009 | Peavey Music
Fujitsu Plasma Screen won't power up
This is most likely caused by the Main Power pcb.
See Fujitsu Service Bulletin on this problem in a similar model from Fujitsu. -see link below
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
A competent service technician should be able to implement the service bulletin.
A similar service bulletin is probably available for your model. Request bulletin from Fujitsu 'service@fujitsugeneral.com'
May 18, 2009 | Fujitsu Plasmavision PDS-4242 42 in....
Blinking Red Standby Light - No picture
The six blinks indicates that an internal fan is either bad ot blocked by dust or debris, You should be able to look in the back of the unit and see some cooling fans. Chances are one on them is not turning and will need to be replaced
Nov 26, 2008 | Panasonic TH-42PHW5 Television
Plasma sound problems
Sounds like the TV volume is set too high, with little or no audio input.
If the sound is coming from the speakers and you are using an external input such as a cable box you may need to turn up the volume output from the box, and turn the TV volume down.
Mar 05, 2008 | Philips 50PFP5332D 50 in. Plasma...
50" Plasma Fijitsu TV
You should go to the audio menu and make sure your not in the SAP(Second Audio Program) mode. also check around at the other features in that audio menu. If still does not work, there is a 3 year warranty on this model. Call up where you bought it and find out who to call for service. Good Luck Ps Please dont forget to rate this thread.
Nov 25, 2006 | Fujitsu PlasmaVision P50XHA40US 50 in....
Televison & Video Logo
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
