Achiever Shredder PS150 not turning on. - Office Equipment & Supplies
  • lizkrinick Feb 07, 2010
    Ok I will try and find the fuse now and get back to you after I do, ok?
  • 11,896 Answers
You can take apart the shredder, and see if there is a fuse in this model. The fuse should have a thin wire running all the way across the fuse. If the wire is broken or burnt, replace it with same size fuse.
If the fuse is good, get a voltmeter, and test the connection where the power supply/high-voltage transformer (the box that has the plug-in attached to it) atttaches to the main circuit board. See what the voltage rating is. If there is no reading or barely any reading, then the power supply/voltage transformer is shot.
Posted on Feb 07, 2010
Testimonial: "it was good info but I took apart shreder and all the wires tlloked intact. Can't find where I should test voltage tho so going to get new machine."
Where can you purchase repair parts? the teeth are stripped on one of the gears. I need a replacement gear for my Achiever SCS-6 Shredder.
I appreciate your intent to help solve my printer problem. However, I do not think it should require me to pay a fee to get an address to locate a Company to obtain a replacement part for my Achiever shredder.
Oct 02, 2009 | Achiever SCS-6 Strip-Cut Shredder
I have an achiever heavy-duty crosscut shredder that I purchased in 2002. Since that time I have actually used the shredder around 5 times. The shredder turns on, shred for about 2-3 mins., then it stops....
does it finish the sheet of paper then shut off , or does it stop halfway thru the paper?
unplug the unit , open it up and see if theres staples or junk jammed in the cutting wheels/gears
there supose to turn off once its finished with the paper and turn back on when the next paper is inserted , theres a lil sensor that turns it on and a limit switch that turns it off
Jul 11, 2009 | Achiever CCS5000 Shredder
I need a manual for my shredder
the overload beeper want cut off and there no paper in it
Aug 27, 2008 | Achiever CCS5000 Shredder
Shredder won't turn on
Has your problem been solved
Please get back to me
Thanks
Jul 07, 2008 | Achiever CCS5000 Shredder
Achiever shredder
The fuse has blown and we need a new fuse for it. We need the fuse number that is on the tip of the fuse. Do you know where we are able to purchase them from?
Jun 10, 2008 | Achiever CCS5000 Shredder
Achiever Shredder CCS5000
Is it on a 20 amp circuit? Check to make sure that it doesn't have a grounding problem or even the plug could be reverse woired.
Oct 10, 2007 | Achiever CCS5000 Shredder
Achiever CCS 5000 Basket
Did you contact Royal Corporation. Look up the model on EBAY and you can find a replacement. I have a used basket from a customer that did not want to repair their shredder. You can have it if toy want to come to Clearwater Florida
Jul 11, 2007 | Achiever CCS5000 Shredder
CCS 5000 Achiever Shredder
You need to purchase a real heavy duty shredder that will handle your work applications. Call 800-342-7362 EG Brennan & Co LLC can help you in this regard!
Apr 12, 2007 | Achiever CCS5000 Shredder
78 people viewed this question
k24674
jasbo
jasbo
